Notices
Jeep cherokee xj Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Jeep cherokee xj
Email Bookmark Print
DUDER1
Mayer
Jeep Information
Year:1998
Model:Sport
Engine:4.0
Transmission:Automatic
Transfer Case:stock
Front Axle:Dana 30
Rear Axle:8.25
Axle Gear Ratio:3.73
Suspension:Three inch rough country
Tires:31x10.5 r15 Falken rm at
Wheels:Black steel
So here is the deal, This is a 1998 jeep cherokee xj automatic 4x4 and it belongs to my mom. She calls me the other day and tells me it just died. So i started looking and when i turned the key i did not hear the fuel pump so i replaced the fuel pump and nothing. The fuel pump dosent prime at all. So i checked the spark and no spark. So i charged the battery clean all the grounds put new terminal on because the old ones were corroded pretty bad and i threw a new crankshaft position sensor in it because eerythinng i have been reading says cps. Nothing. I checked the relays moved them around still nothing but i did check where the relays plug in and they all had one hot terminal so there getting power. A little while befor the happened the cluster went out with the radio and the door locks. The jeep would sometimes sputter and then smooth out. I put new plugs cap and rotor along with wires and still same thing. I am at a loss with this thing my zj was kind of doing the same thing and i replaced the ecm and it runs perfect now. I think its the ecm but i hope someone has a better idea about this. Thank you very much.
None
Login Or Register To Post Comments
DUDER1
View DUDER1's Jeep
09-07-2012, 02:52 PM
Thanks again.
UAVXJ
View UAVXJ's Jeep
09-10-2012, 07:41 PM
If you don't have power to anything else it may be your ignition switch.
ThreadThread StarterForumRepliesLast Post
jeep Cherokee griffrider XJ Cherokee 2 08-28-2012 05:31 PM
2000 jeep cherokee 4x4 Buns07 XJ Cherokee 2 06-30-2012 10:45 PM
Jeep Cherokee andbeforedrew XJ Cherokee 0 06-11-2012 08:12 PM
Jeep Cherokee Limited 4x4 jcarli86 XJ Cherokee 0 03-07-2011 12:57 AM
jeep cherokee Beehive49 XJ Cherokee 0 01-12-2011 03:25 AM
