Go Back JeepForum.com > Jeep Registry > XJ Cherokee > Cherokee
Cherokee Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Cherokee
Email Bookmark Print
flyer21144
Jeep Information
Year:2000
Model:Sport
Engine:4.0 L
Transmission:Automatic
I was attempting to replace rear shocks on my 2000 cherokee. I sprayed penetrating oil three days in a row, the first was changed out without complication however the second created what I perceive as a nightmare. The two problem top bolts were fine but the main pin on the bottom sheared flush with the shock. How is this issued fixed? Please help.
None
Login Or Register To Post Comments
JeepXJ20
View JeepXJ20's Jeep
10-09-2012, 10:26 PM
Cut off the whole shock mount with a zip cut and buy or make or cut off another shock mount off the same axle and weld it back into the same spot. Then install shock.
