Buckwild Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Buckwild
Email Bookmark Print
jeepersilva
Jeep Information
Year:1988
Model:XJ Cherokee Pioneer
Engine:4.0L I6 EFI Powertech 177hp @4750rpm 220 ft lb @4000 rpm
Transmission:AW4-4 Speed Automatic
Transfer Case:NP231 Command-Trac Part-time only 2.72:1 ratio low range shift pattern 2H-4H-N-4L
Front Axle:Dana 30 High Pinion -reverse cut -27 Spline, 1.16" diameter shafts, 7.13" Ring gear
Rear Axle:Dana 35 Non C-clip -27 spline, 1.18" diameter shafts, 7.58" Ring gear, 2.62" Axle Tube
Axle Gear Ratio:3.5
Suspension:Stock
Tires:31x9.50
Wheels:15 inch rims
Future Modifications:Front Grand Cherokee Coil Springs, Rear Dodge Dakota Leaf Springs, One Inch body lift, 33-35' inch tires
I don't even know what to put here
None
Login Or Register To Post Comments
