Go Back JeepForum.com > Jeep Registry > XJ Cherokee > Blair's Jeep
1995-1998 Jeep Grand Cherokee Front & Rear Brake Pad &Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Blair's Jeep Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Blair's Jeep
Email Bookmark Print
ajb50402
Jeep Information
Year:1996
Model:Jeep Cherokee Country
Engine:4.0 L Straight 6 cylinder inline
Transmission:Automatic
Transfer Case:Factory
Front Axle:Factory
Rear Axle:Factory
Axle Gear Ratio:Factory
Suspension:Factory
Tires:UNK
Wheels:Factory
Armor:Factory
Recovery Gear:Factory
Accessories:none
Future Modifications:new suspension, reparing rust, possible lift kit
Hey everyone! I am new on here so any advice would be needed. I am currently in the army and just bought this jeep cherokee. It is forest green with 165,000 miles on it, automatic transmission. I am currently scrubbing rust off of the underside by hand and resurfacing it. The exhaust pipe right past the muffler by the rear axle has also rusted a hole about 1 inch in diameter so I am going to replace that. The check engine light is also on so tomorrow I am going to get that looked at but I am guessing that is from the oxygen sensor. Any other suggestions? I need this baby to last me another 4 years!
None
Login Or Register To Post Comments
Tim_13
View Tim_13's Jeep
06-10-2012, 03:13 PM
Don't know if you're in Georgia or not but Google Outback Jeep of Roswell. Talk to Jeff. This guy is an expert jeep mechanic.
danpick
View danpick's Jeep
06-24-2012, 05:44 PM
Great info I'm in Columbus ga and my 1999 is going through a major service on rear end and any expert close by is great !
ajb50402
View ajb50402's Jeep
07-23-2012, 11:31 PM
Great thanks for the help! I'm actually in Nebraska but I might be stationed down in Columbus, GA for the army. And just replaced the cooling system on mine: some idiot before
Me put the cheap sealant stuff inside of it to try and fix it and clogged it all up. Still leaking some transmission fluid from the bottom transmission cooling line at the point where it connects to the radiator. Next major project: cold air intake!
