Go Back JeepForum.com > Jeep Registry > Commando > Fix It
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Fix It Jeep Registry
Previous Jeep Commando Next Jeep
Fix It
Email Bookmark Print
jeffsmanyjeeps
central jersey
Jeep Information
Year:1973
Model:C 104
Engine:AMC 360
Transmission:TH 400
Transfer Case:Dana 20
Front Axle:Dana 30
Rear Axle:Dana 44
Axle Gear Ratio:3.73
Suspension:stock and tired
Tires:white walled radials!
Wheels:stock steel with factory hubcaps
Armor:old faded paint
Recovery Gear:cell phone
Accessories:mice and snakes, HEI and a rebuilt 2 bbl.
Future Modifications:44 front, 60 rear, spring over front, 3 link rear
I rescued this half cab from impending doom about 3 years ago and got it going pretty good now. Did a fuel, water pump, new gas tank, wheel cylinders and brake hardware. New HEI distributer set to 12 degrees advanced and the Motorcraft 2 bbl, i now SMOKE THE TIRES!! All the freeze plugs were rusted out. Compression test was perfect and no leaks or smoke. Next is B&M shift improver kit and Megashifter. 2011 will spring over probably these stock axels and arch and double up the spring pack. The 8- lug full width axels i just picked up will need to be gone thru. Not sure if i am ready to go that route yet
None
Login Or Register To Post Comments
