Ziebart displaces moisture when applied??? - JeepForum.com
post #1 of 4 Old 09-06-2008, 09:25 AM Thread Starter
Bayrat
2014 JK Wrangler
I just called to schedule an underbody Ziebart job for my new Rubicon and I asked the guy about a wet chassis in the event it is raining when I make the 40 mile trip.
He says that the undercoating will displace any water or moisture when it is sprayed. I am a bit doubtful of that. Does anyone know this for sure?
I am going to hold my breath that it does not rain that day, if it does I may cancel. Price is not bad $199 and with all the salt around here in the winter I figured it could not hurt.
Bayrat is offline
post #2 of 4 Old 09-07-2008, 06:44 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
I wouldn't worry about it. I should do this as well. Let us know how it goes.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #3 of 4 Old 09-07-2008, 08:24 AM Thread Starter
Bayrat
2014 JK Wrangler
Well, I did a bunch of research on this subject and one thing I found is that spraying it over water is one of the worst things you can do. Given this, I called and cancelled last night as now I feel the entire process is suspect. Going to try to do two good chassis cleanings a week during salt season instead.
Bayrat is offline
post #4 of 4 Old 09-15-2008, 05:56 PM
dawnskaybug
dawnskaybug's Avatar
Money well saved..
05 LJ
RE 4.5 SA 1inch BL
Aussie front Detroit rear 4.88s
1200 series Tractor tires (37x10)
Warn winch stinger
Lotsa trail damage
dawnskaybug is offline
$45 DIY headiner (on cherokee but can be applied for any vehicle) Cantstopspinning Cheap Tricks & Fixes 51 04-30-2017 04:06 PM
Desiccant material for moisture trap... Saltine Fabrication Shop 4 09-17-2009 11:00 PM
welding rod picking put moisture? RedMountainYJ Fabrication Shop 16 01-20-2008 09:32 PM
electronic / moisture problem TJ on the Rocks Audio, CB & Ham Radios, GPS, & Electrical 5 04-20-2007 03:52 PM
engine stalls when brakes are applied dhammonds2369 Engines & Drivetrain 6 02-28-2004 05:56 PM
