Yj lights - JeepForum.com
post #1 of 3 Old 10-07-2013, 02:52 PM Thread Starter
simonwarren1966
Yj lights
Just put 90/130 bulbs into my yj jeep wrangler as the lights are like driving with candles!!
Question is -will it burn out my wiring as the lights switch seemed to get quite warm???? Someone suggested changing a regulator .. Will this work .
simonwarren1966 is offline
post #2 of 3 Old 10-07-2013, 04:14 PM
uberxj92
1992 XJ Cherokee
Older jeeps had bare minimum wiring harnesses. Check your grounds and the headlight relay
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 3 Old 10-07-2013, 08:53 PM
jokerchief462
If they draw more than standard the old TJ switch will overheat and the go on and off like blinking your headlights. The wiring will get warm. Go to the YJ page there is someone with headlight problems a great link to the headlight relay mod for the YJ a perfect fix for this.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
