Windshield Light Brackets - JeepForum.com
post #1 of 7 Old 12-21-2009, 12:58 PM Thread Starter
CHAYES911
2009 WK
Hey fellow JEEPers! I just bought some windshield light brackets and wanted to know the best way to run the lights with the least amount of exposed wires. Any ideas or photos would be great guys. Thanks.
CHAYES911 is offline
post #2 of 7 Old 12-22-2009, 08:54 AM
bward623
i came down about 2 inches and over about 4 inches and drilled a hole throught the sheet metal, i pulled all of my wires through the holes and then wrapped them in wire covers. It looks pretty good since they both look about the same.
bward623 is offline
post #3 of 7 Old 12-22-2009, 02:21 PM
fernjack
I loosened the trim cover on the base of the windshield and fed the wires up behind it and re-tightened it (JK) worked fine no drilling and minimal pinching on the wire loom .I`m using Light Force lamps , they put a bit of glare on the hood but not to bad and are very bright . They are also made of carbon fibre so no rusting and as far as being tough they shoot them with #7 1/2 out of a 12ga. !
fernjack is offline
post #4 of 7 Old 12-22-2009, 05:08 PM
willydigger
Not my Jeep, but this is the best I've seen. It's from this thread.
willydigger is offline
post #5 of 7 Old 12-22-2009, 07:19 PM Thread Starter
CHAYES911
2009 WK
Wow that loks really good. I juust finished and what i ended up doing was cutting a little peice of the corner off. Thanks for the help and ideas guys. I wish i had seen this picture first though!
post #6 of 7 Old 12-24-2009, 11:26 AM
general
GEDC0165.jpg picture by curtisgurnett - Photobucket
I liked the idea of not having to drill holes anywhere so as you can see in the picture I just ran them through the slot in the door.
general is offline
post #7 of 7 Old 12-24-2009, 11:37 AM
JIMBOX
Checout for clearance, then drill a hole on each side for the grommett (probably came with your lights) then the install looks good, don't stuff them in a crack then it looks "temporary"
Don't have any close pics but willydiggers pic is close
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
ever made windshield light brackets? fortz Fabrication Shop 5 11-05-2009 12:09 AM
Ideas on Light brackets for windshield flexsaharatj Fabrication Shop 2 11-25-2008 08:56 AM
Windshield Light Brackets brianksain Audio, CB & Ham Radios, GPS, & Electrical 2 04-17-2008 07:35 PM
Installing KC Windshield Brackets TheDiabetic General Jeep & Off-Road Equipment 0 02-24-2006 09:30 AM
Windshield light brackets dan240 General Jeep & Off-Road Equipment 3 05-08-2003 03:14 PM
