#1 | |
Wrangler
winches
so i am looking to buy my first winch. i wheel with a couple buddies and i am the only one wth a jeep and the only one that doesn't continuously get stuck
they all wheel fullsize trucks. i have been looking into the warn M8000. my question is since they all have bigger trucks and are willing to chip in a lil bit on the winch should i go bigger. also how big is too big. if i go with a 12,000lb winch am i gonna rip my bumper off. or snap bolts. or bend someting. i would assume my wheels would start slipping across the ground before any of that happens but ya? any input?
#2 |
Do it right or not at all
![]() Join Date: Jan 2003
8,000 to 9,500 lbs. is perfect for a Wrangler. You'll often drag yourself when winching bigger vehicles but a 9000 to 9500 lb. winch would be ideal for your situation. I'm running a 9500 lb. Warn winch and I've hauled several big trucks up hills/obstacles without much strain. Learning how properly to keep your Jeep from being pulled to the stuck heavier vehicle is key though. Personally I like my Jeep to be slightly over the top of the hill to prevent it from being dragged while winching if possible.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#3 |
don't know if its recommended or not but i'll secure my back bumper to a tree with a tow strap if i start to slide. i've got an 8000 lb one.
#4 |
Wrangler
perfect. i think the warn 8000lbs is the way i will go. but i have seen a few other winchs posted on qaudratec for a few hundred lower. also 8000lbs. worth the savings or stick with warn?
#5 |
my buddy's mile marker seems nice but he hasnt put many "miles" on it yet... so i don't know long term on his. mine's pretty old ... heres me with mine yesterdayhaha.. pulling the front end down.. and i'm tied off to a tree in the back. he kept pulling me down the hill in the mud. ![]() |
#6 |
oh and ps.. don't let them pay you for your winch!!!!!!
thats just ASKING for phone calls late at night to ask for help getting out of a mud hole... |
#7 |
I have an M8000 and it has always pulled me out easily. It pulls the only fullsize truck in our club fairly well, It just strains a little when its extra stuck.
70's chevy on 39's. You could always use a pulley if you arn't getting enough power.
Superior axles doesn't honor their warranty. Don't buy from them. |
#8 |
you can always tie off to another rig as an anchor or shift into 2 wheel drive wile hooked up and dig the rear tires in reverse..And remember if using a snatchblock make sure your anchor point on your jeep is strong enough to hold twice the load..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#9 |
Wrangler
thats what i mean. whats a good winch plate and whatever to use. grade 8 bolts? ect
#10 | |
#11 |
man..
sometime you gotta do what you gotta do. he has a winch but it's off right now, getting recovery points put on. the irony! |
#12 | |
1994 XJ - 4.5" lift, 33x12.5 Super Swamper radials, etc... White Jeep Club Member # 1994 Is it done yet??? |
#13 | |
#14 |
i think 9500 lbs would be more than enough to pull out a full size truck. I pulled a guy out of ditch one time in an 03' GMC extended cab 4x4 he tried to go across the ditch and his front bumper was shoved up againt one bank and his rear bumper was against the other bank of the ditch and he had zero traction from his crappy tires. I had to strap up to an F250 to keep from sliding but the Mile Marker SI9500 did the job.
#15 |
Get a pull-pal to go along with it. I pulled a Suburban that had it's front end sitting in the mud a few weeks ago. Without the pull-pal there's no way I would've kept from sliding - sometimes there just isn't a hill nearby.
Don't forget the snatch block either. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
