Winch(xd8000i) wont pull line, but will push it...barely used - JeepForum.com
post #1 of 13 Old 05-23-2010, 08:28 PM Thread Starter
nlummus2
I have had my winch(xd8000i) for about 2 years now, only used 3x and very lightly at that. Unfortunately, I got into a wreck about a month ago and my winch took some damage on the left side(pic links below). Although, i tested the winch after the wreck and it worked fine, but now it seems to only to feed the line out. When i try to pull the line back in it just clicks and there is no movement. I have never taken a winch apart and am I little confused on what to do.
By lummus2930 at 2010-05-24
nlummus2 is offline
post #2 of 13 Old 05-23-2010, 08:29 PM Thread Starter
nlummus2
wow, way to big, sorry! lol
nlummus2 is offline
post #3 of 13 Old 05-24-2010, 03:20 PM Thread Starter
nlummus2
bump......
2005 TJ Wrangler, 4.0L, 6 Speed, Drop, 3" Suspension Lift(Transfer Case 1"), 33x12.5x15 BFG M/T, American Racing Wheels, XD8000i(synthetic line, with thimble), Poison Spider Rock Sliders, A/T Rock Rear Bumper and Front Bumper, KC Fog Lights, CB Radio, Herculiner inside,
nlummus2 is offline
post #4 of 13 Old 05-24-2010, 03:40 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That the motor works in one direction and not the other likely indicates something besides the motor is responsible for the problem. There are four solenoids underneath the top cover with the big red Warn on it. Two of those solenoids (remote control heavy duty switches) provide the 'In' direction connection to the motor, the other two provide the 'Out' connection to the motor. Are you competent with a meter & can work on a live DC circuit without frying it or doing any accidental welding?
Jerry Bransford is offline
post #5 of 13 Old 05-25-2010, 03:11 PM Thread Starter
nlummus2
yes i am, lol
nlummus2 is offline
post #6 of 13 Old 05-25-2010, 04:55 PM
Jerry Bransford
Administrator
Originally Posted by nlummus2 View Post
yes i am, lol
Based on that, remove the screws on the side of the housing that hold the top/middle cover in place. That will expose the solenoids. Before I forget to say this, don't overtighten those long side screws when you replace the cover as they are only threaded into aluminum.
Two of those solenoids are working on the 'Out' side, one or two of the solenoids on the 'In' side are likely the problem. If you have a test light or meter, place it across each solenoid's main (big posts). The light will glow or the meter will indicate 12 volts when the solenoid is inactive and the light will go out & the meter will go to 0 volts when the solenoid is activated. See if one of the four solenoids gives a different symptom when going back & forth between In and Out. If they do, disconnect the winch's positive lead from the battery. Then loosen & retighten both the small and large connectors at the solenoid, you are of course looking for a loose or bad connection at this point. You can also feel the solenoids as they energize, if they are energizing that is.
Whoops, newer Warn winches don't have a ground supplied to the solenoids until energized with the remote so the above may not work when the solenoids are not activated. However, a solenoid that is not working properly when energized will show 12 volts across its big lugs since those two big lugs go to the connector inside... which when making a connection will connect those two lugs together.
I have a photo of my old Warn winch internals at home, its solenoids may be marked well enough to know which solenoids are for In and Out. If it does, that will help & I'll post it at night. If it doesn't, I can't look to see because that is the winch that was on my TJ that was stolen in March. My replacement Warn (9.5 XP) winch has its solenoids layed out differently.
post #7 of 13 Old 05-30-2010, 11:10 PM Thread Starter
nlummus2
if i figure out it is the solenoids, which i will test tomorrow...is there a website that i can buy them from? cost estimate?
also, if they look like there working and connected properly what should i try next?
nlummus2 is offline
post #8 of 13 Old 05-30-2010, 11:41 PM
Jerry Bransford
Administrator
Let's take this one step at a time & assume the problem is with a solenoid or the wiring leading to/from a solenoid. If it turns out to be a bad solenoid, I have used this source for solenoids to fit a Warn winch in the past: DB Electrical Starter-Alternator > winch solenoid,prestolite solenoid,universal solenoid,solenoid
post #9 of 13 Old 05-31-2010, 08:54 AM
MattIngram
I am going through the same thing. I have a solenoid out on the "in" side. A buddy of mine said don't waste your money on the more expencive solenoids, just go get a $8 dollar one at the parts store for like a ford. Is there and truth to that? I don't know much about them, but the way I look at it, the starter solenoids are ment for short "bursts" instead of long consent pulls? Am I seeing that right?
MattIngram is offline
post #10 of 13 Old 05-31-2010, 09:52 AM
Jerry Bransford
Administrator
Your buddy would likely end up with a dead winch when he really needed it to work after a while using an inexpensive "in a can" style solenoid that isn't all that well sealed against moisture. To me, paying $19.50 for a sealed solenoid ($39 for a pair actually) from that website I suggested is the wise way to do things since a winch sits outside & is exposed to all kinds of nasty stuff.
post #11 of 13 Old 06-09-2010, 05:41 PM Thread Starter
nlummus2
Here is winch just sitting
By lummus2930 at 2010-06-09
Here is winch with PUSH
Here is winch with PULL
nlummus2 is offline
post #12 of 13 Old 06-10-2010, 05:45 PM Thread Starter
nlummus2
bump......
nlummus2 is offline
post #13 of 13 Old 06-11-2010, 10:10 AM Thread Starter
nlummus2
bump......
nlummus2 is offline
winch , xd8000i
Jeep barely will pull itself when after cold start viperbluelx TJ Wrangler Technical Forum 6 05-05-2010 02:21 PM
Surge push/pull under acceleration alexr40 TJ Wrangler Technical Forum 4 08-06-2008 09:38 AM
Push or Pull? Wild Buckin' TJ Wrangler Technical Forum 3 03-23-2005 03:09 PM
Which Synthetic Winch Rope: Amsteel or Master Pull Stricken TJ Wrangler Technical Forum 3 07-27-2004 09:22 PM
Push-Pull cable raZe YJ Wrangler Technical Forum 1 01-21-2004 04:58 AM
