Winch tree/stump removal? - JeepForum.com
post #1 of 34 Old 03-20-2009, 03:58 PM Thread Starter
neonistic
1981 CJ7
Has anyone done this? What is the "proper" procedure?
You're going to hate Fridays!
neonistic is offline
post #2 of 34 Old 03-22-2009, 11:40 AM
0okamiDigital
here how not to do it...
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/GkuG_RTS15I&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/GkuG_RTS15I&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
0okamiDigital is offline
post #3 of 34 Old 03-22-2009, 02:04 PM
RikRotorhead
The homeowner say's "Now that you have it in your truck, can you haul it to the dump for me?"
How obvious was it that that was going to happen? He's lucky he didn't get squished.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #4 of 34 Old 03-22-2009, 06:17 PM
Amadeus3
1997 XJ Cherokee
That would have been a great Darwin award had he been successful.
6.5" Rough Country lift, locked on 35x12.5x15" BFG KM's, Nate's 4x4 Slimline, Smittybilt XRC10, skids, random junkyard upgrades
Amadeus3 is offline
post #5 of 34 Old 03-23-2009, 01:27 PM
jeepnphreak
1989 XJ Cherokee
That was funny as hell. How cold you not see that was going to happen.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #6 of 34 Old 03-23-2009, 03:02 PM
jdarg
Back OT. I had to winch a few trees for a friend of mine one. His property was on a 30' rocky hill overlooking a lake, with the edge of the yard at the top of the hill and the trees towards the bottom. When he cut the trees they'd fall down into the water. From there we'd cut them into about 10 foot sections and winched them up the hill no problem. Make sure you use a properly rated chain, shackles, etc. around the tree and not a strap. The strap could get ruined by dragging it over the ground...this is one place where a chain should be used.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #7 of 34 Old 03-23-2009, 03:08 PM Thread Starter
neonistic
1981 CJ7
But what about removing the stumps?
post #8 of 34 Old 03-23-2009, 03:12 PM
FarmBoy
I doubt a winch is going to be of any use pulling a stump of any size. A winch is not supposed to be used for pulling.
Back in the say it took a pretty good tractor to pull stumps. If your trees are have any size to them you'll need to dig and cut the roots first.
-jeff b.
1995 YJ 4 cyl auto, 2" BDS springs, BDS shocks, and 1/2 lift boomerang shackles. 31" BFG Mud Terrain.
FarmBoy is offline
post #9 of 34 Old 03-23-2009, 04:17 PM
Amadeus3
1997 XJ Cherokee
yeah a winch is not going to do it. depending on the size of the stump you need to get under it and cut the roots. Even excavators have a hard time with stumps. If you can you should just hire someone to grind it down, its easier, quicker, and you won't have a gigantic hole and a stump to dispose of.
Amadeus3 is offline
post #10 of 34 Old 03-23-2009, 04:41 PM
ninemili22TJ
I pulled a stump out yesterday in 4L with a tow strap
ninemili22TJ is offline
post #11 of 34 Old 03-23-2009, 07:47 PM Thread Starter
neonistic
1981 CJ7
I was figuring that here it would be easier to pull a stump because the soil layer is so shallow. Usually less than 2 feet before hitting bedrock (lava). The trees I want to remove are sapling size trees.
post #12 of 34 Old 03-23-2009, 08:56 PM
Lifesgoodhere
I do it all the time with the 12,000 lb winch on our 1980 GMC truck...works great, and its quick. I chock all 4 wheels with a 6 X 6 block of wood, I also set the parking brake. I throw a old bath towel over the winch line while pulling, just in case. To make it easier, I dig around the stump of the stump or tree, to loosen the soil a bit. Best to do this right after a good day of rain.
Hell I have pulled down old horse run-ins and old chicken houses we have on our farm with that winch.
A Jeeper for life
Lifesgoodhere is offline
post #13 of 34 Old 03-23-2009, 09:34 PM
RikRotorhead
Saplings shouldn't be a problem for a good winch. You should be able to pull the entire tree and stump at the same time.
Soak the ground around the stump after you dig a bit around it. Cut the big roots that you can.
A towel on the winch cable is good, but a piece of carpet or old rug would be better in case the chain let's go.
Take pics and post them.
RJC#512
post #14 of 34 Old 03-24-2009, 07:09 AM
mdm
Farm Wheeler
Originally Posted by FarmBoy View Post
I doubt a winch is going to be of any use pulling a stump of any size. A winch is not supposed to be used for pulling. ...
I agree that a winch won't be a lot of use in pulling a big stump but I do have to ask - What do you do with your winch? Push??
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #15 of 34 Old 03-24-2009, 08:09 AM
242much
2009 JK Wrangler
lol, beat me to it.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
Can I use a High lift to pull out a tree stump? funJ General Jeep & Off-Road Equipment 5 08-07-2009 08:15 AM
CJ5 PTO winch removal help! Gloftoe General Jeep & Off-Road Equipment 1 07-09-2009 06:11 PM
Tree sap won't come off... mopar3389 General Jeep & Off-Road Equipment 29 04-03-2009 01:23 PM
metal vs. tree claytonandson General Jeep & Off-Road Equipment 3 06-15-2006 11:42 PM
Tree sap vs. soft top dalby Cheap Tricks & Fixes 2 02-09-2006 11:03 AM
