Winch size? - JeepForum.com
post #1 of 10 Old 10-07-2001, 02:39 PM Thread Starter
rsmnc
Winch size?
I'm starting to consider adding a winch, but am not too sure what size to get. I mainly drive fire roads that aren't too difficult... 1-2. What is the minimum size I should be looking at for my YJ?
'89 YJ 2.5L
30x9.5x15 (no lift yet)
rsmnc is offline
post #2 of 10 Old 10-07-2001, 06:46 PM
osburn
osburn's Avatar
For a YJ, I wouldn't consider anything smaller than an 8K.
Matt Osburn
Score 1032
osburn is offline
post #3 of 10 Old 10-08-2001, 05:36 AM
Jeep Chic
I agree completely with Osburn, I have the Warn x8000i mounted on a Tomken winch plate w/brush guard. I am very impressed with it, and it was a relatively install.
Jeep Chic is offline
post #4 of 10 Old 10-08-2001, 02:05 PM
mytjnamedrex
ive heard the figure of 2x vehicle weight but i could be wrong....all i know is my friend bought a 4500 lb and couldnt get out of the mudhole i think a min of 6k if its stock and larger as the vehicle is larger. Just my take on it..i dont have one but am savin up for an 8k.
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #5 of 10 Old 10-10-2001, 08:06 PM
CdnJeepGirl
I was asking one of these guys at a 4x4 shop about a 9500...he said it would be overkill for my semi-stocker...he told me that the 8000 would be just fine...I wheel in the Canadian Rockies...bogs galore for everyone!
'03 Rubi
Locked...Loaded...Broke :D
CdnJeepGirl is offline
post #6 of 10 Old 10-11-2001, 07:18 AM
Bailey TJ
8000 should be good. You also have to keep in mind the weight of the rig you might be pulling out someday too
"Never test the depth of a river with all 4 wheels"
Bailey TJ is offline
post #7 of 10 Old 10-11-2001, 09:37 AM
CdnJeepGirl
A tree saver is a must too...both for winching yourself and to hook your back end to a tree when you are winching someone else who may be a little heavier(rig-wise or bogged in good). Another good thing is to practice BEFORE you get on the trail so you know how your winch works, how to hook up, and so the misc noises don't catch you off guard. Learn proper maintenance and make sure you either weld your winch on to your bumper, or have some other way to lock it on...it WILL be "borrowed" if you don't. HTH
EDIT: speeling, eh.
'03 Rubi
post #8 of 10 Old 10-11-2001, 04:27 PM
iJeep
take the vehicle weight times 1.5...You have to account for the resistance of mud or large rocks and steep hills...I would personally do a 9000lb'er...You can get an electric if you want short and quick pulls, or a hydraulic for long uphill or wet and muddy pulls. Personally I was looking thru a MileMarker catalog today and I think I am going to go that route.
iJeep is offline
post #9 of 10 Old 10-11-2001, 06:49 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
I've got a Warn 8000 up front that has always had enough guts for whatever I've asked it to pull. I just got a Warn 6000 and put it on a receiver mount for the rear and I can swap it to different vehicles if I want to. The line speed on the 6000 is 26 feet per minute which kicks the crap out of my 8000. I really do like the faster line speed of the 6000. If you're looking at a new winch, you might want to consider line speed as a deciding factor in your final choice.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #10 of 10 Old 10-11-2001, 07:06 PM Thread Starter
rsmnc
Thanks for all the feedback. I've priced a few 8000's, now if I could find some extra money this month!!
'89 YJ 2.5L
rsmnc is offline
What size winch is best?? Dan's YJ General Jeep & Off-Road Equipment 33 01-08-2011 07:28 AM
winch size boone78 General Jeep & Off-Road Equipment 6 04-06-2009 02:29 PM
Size Winch Brindle19 General Jeep & Off-Road Equipment 7 10-12-2005 03:34 PM
What winch size? fastfive0 General Jeep & Off-Road Equipment 17 08-13-2003 06:42 PM
Winch size and miniatures sulaco General Jeep & Off-Road Equipment 7 10-11-2002 11:15 AM
