Which winch plate is flat to frame and will hold my winch close to grill? - JeepForum.com
post #1 of 6 Old 02-20-2010, 12:06 AM Thread Starter
CB3
I have no stock swaybar (replaced by a Curre Anti-Rock). So no need to clear stock swaybar.
I want a winch plate that fits flat to frame and mounts winch as far back towards grill as possible.
I just ordered a Superwinch EP9 and will use rope on it.
I need a winchplate for it.
Recommendations?
CB3 is offline
post #2 of 6 Old 02-20-2010, 01:06 AM
ClimbStuff
Originally Posted by CB3 View Post
I have no stock trackbar (replaced by a Curre Anti-Rock). So need need to clear stock trackbar.
Recommendations?
You mean the sway bar? I think just about all of them out there mount to the same set of holes on the frame rails. They all sit similar too... I think its because the cross bar in the front would get in the way of the mounting bolts if it was moved any forward or backward...
ClimbStuff is offline
post #3 of 6 Old 02-20-2010, 05:32 PM
sstaurus
sstaurus's Avatar
A couple sit further back, for instance Smittybilt has a normal flat plate, and a raised version which allows it to sit back a bit more over the swaybar.
'02 Sienna Pearl TJ Sahara
sstaurus is offline
post #4 of 6 Old 02-21-2010, 09:16 AM
brownbagg
1930 MK Compass
plate steel
brownbagg is offline
post #5 of 6 Old 02-21-2010, 11:05 AM
jondotcom
Originally Posted by brownbagg View Post
plate steel
Yeah ditto that. All of the flat ones I've seen sit forward due to the sway, but since you want flat an where the sway normally is you can just drill a big piece of plate steel.
It will take time to restore chaos- GW Bush
jondotcom is offline
post #6 of 6 Old 02-23-2010, 09:23 PM Thread Starter
CB3
OK, thanks.
CB3 is offline
Warn Winch and Winch Plate Advice BigGreenTJ27 General Jeep & Off-Road Equipment 4 09-22-2009 02:35 PM
Please advise on winch,plate and grill guard on stock bumper!! jeep2008 General Jeep & Off-Road Equipment 10 06-17-2009 07:16 AM
Winch plate without winch? ShinySideUp General Jeep & Off-Road Equipment 5 01-23-2009 12:09 PM
Warn winch close-out....and other SALES!! Zamboni68 General Jeep & Off-Road Equipment 8 09-01-2008 03:18 PM
Winch plate on non winch bumper. Ski01xj Fabrication Shop 6 09-14-2007 09:26 PM
