Winch Maintenance - JeepForum.com
post #1 of 6 Old 07-29-2013, 02:33 PM Thread Starter
twhditto
twhditto's Avatar
Winch Maintenance
Just wondering about any particular comments on how to maintain my Warn Winch I just put on over the weekend. I have a cover on the way and read that you make sure that the cable is dry before putting it back on the roller and to make sure it is nice and straight. Any other particulars? Thanks in advance.
Tom in the Great State of Arkansas
2003 Rubicon, stock - but building - slowly... in Van Buren, AR
twhditto is offline
post #2 of 6 Old 07-29-2013, 02:40 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to General Jeep & Off-Road Equipment Forum.
Wheelin98TJ is offline
post #3 of 6 Old 07-29-2013, 08:51 PM
Filthy-Beast
I put dieltric grease in the contacts for the controller to keep them from corroding.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #4 of 6 Old 07-31-2013, 08:03 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Which winch is it. The 8274 has a lot of mods you can do but I am not sure of the rest.
8274:
create oil fill and drain - done
grease electricals - done
move solinoid pack into engine compartment - just did but havent installed
swap solinoids for superwinch control box - just did but havent installed
take apart, grease and rebuild - done
powdercoat or paint - done
convert to double motor for a mind blowing line speed - still on the long list
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #5 of 6 Old 08-07-2013, 12:20 AM
karlo
Here's a good thread on how to take care of your winch - http://www.jeepforum.com/forum/f27/h...-help-1299317/
karlo is offline
post #6 of 6 Old 08-07-2013, 05:59 PM
GilaMtnJeep
GilaMtnJeep's Avatar
That thread also asks about theft protection. Although a ton of locktite would make it hard for thieves it would make it hard for you as well. Tuffy sells a product called a "bolt locker". It's a two piece steel cover for one of the plate mounting bolts (usually the front two winch bolts are inaccessible until the mount is removed). One half goes on with one of the plate mounting bolts and the cover locks to it. It is made from 1/4" steel so it is quite durable.
Pics
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
