Winch cable/wire rope - questions/answers?
#1 | |
This thread is dedicated to all things about winch cables, whether it be wire rope, safety, usage, maintenance, or synthetic rope.
I am not a cable expert. What I post in this thread is from either reference material I have found, observation, or my opinion! This thread was spurred by my off-topic posts in this thread: http://www.jeepforum.com/forum/f27/winch-fixed-removable-326130/ I'll start us off with some info from that thread: . .
#2 | ||
#3 |
Winch cable (wire rope)
I did a bit of research on this a while ago, and had a good thread on it, but it was General Discussion, and looks to be gone. Here's some info from another thread http://www.jeepforum.com/forum/f27/snatch-block-theory-205210-post1549255/........ The working load rating on a 8,000 lb winch cable is only 1,960 lbs. Did I say that loud enough? Yup, all these winches are running cable rated for about 1/5th the capacity of the rest of the parts. And when you snatch-block it, the load at the pulley is about double the load of the pull. Now you're putting 16,000 lbs of load on a cable whose working load is 1,950 lbs (and its breaking rating is about 9,800 lbs!). (1) If you find it hard to believe that winch manufacturers are selling winches rated for loads that are dangerously close to the breaking strength of the cables, believe it. Let's not forget, breaking strength is determined in testing conditions on new, undamaged cable, in a controlled testing environment. Safe working load (SWL) for pulling is determined by dividing the breaking strength (straight-line pull, lab conditions, undamaged cable) by 5. This is called a safety factor of 5. To use a snatch block with an 8,000 lb winch, you'd want to be running cable rated for 16,000 x 5 = 80,000lbs to stay within the SWL of the cable. That would be a cable about 1 inch thick.(2) References: 1) http://www.rigging.net/wire.html 2) Area of a circle (I know wire rope isn't a true circle) pi * r2 ....the BREAKING load rating on 3/8" cable (common on winches over 9000 lbs) is about 14,000 lbs, and the safe working load (SWL) is 2,880 lbs (yes, that is right, 2,800 lbs). Size (Inches) ......SWL (Lbs.) 3/32 ....................... 200 1/8 ......................... 400 5/32 ....................... 560 3/16 ....................... 840 7/32 ...................... 1000 1/4 ........................ 1400 5/16 ...................... 1960 3/8 ........................ 2880 ![]() This is one of those winching subjects that I think everyone should be aware of. Here is a great source of info: http://www.pirate4x4.com/tech/billavista/Recovery/index.html Last edited by CNY; 10-13-2006 at 08:15 AM.. |
#4 | |
http://www.masterpull.com/cpage.cfm?cpid=197
![]() Quote:
WIRE ROPE SAFE WORKING LOAD The term safe working load (SWL) of wire rope is used to define the load which can be applied that allows the rope to provide efficient service and also prolong the life of the rope. The formula for computing the SWL of a wire rope is the diameter of the rope squared, multiplied by 8. D x D x 8 = SWL (in tons) Example: The wire rope is 1/2 inch in diameter. Compute the SWL for the rope. The first step is to convert the 1/2 into decimal numbers by dividing the bottom number of the fraction into the top number of the fraction: (1 divided by 2 = .5.) Next, compute the SWL formula: (.5 x .5 x 8 = 2 tons.) The SWL of the 1/2-inch wire rope is 2 tons. So if we plug our 5/16" wire rope into the Navy's formula: Wire rope is 5/16 inch in diameter. convert the 5/16 into decimal numbers = 0.3125 Compute the SWL formula: (0.3125 x 0.3125 x 8 = 0.78125 tons.) The SWL of the 5/16-inch wire rope is 1562.5 pounds. |
#5 | |
* the cable is being used within its breaking strength of 9,800 lbs * Most winching operations aren't done on the first wrap of the drum (the only place you can come close to an 8,000 pull (on an 8,000 lb winch)). * Most people aren't injured, even if the cable fails I'll admit, that a lot of factors have to line up for someone to get hurt by a parting winchline, but that doesn't change the fact that the SWL of a 5/16" cable is less than 2,000 lbs. Go down to your local farm supply store, and look at the 5/16" cable they have on display. You won't see a working load listed anywhere near 8,000 lbs. |
#6 | |
#7 | |||||
Also, the one warning that does come with all winches is that they are not to be used for overhead lifting. I know you didn't say they should be, but my point is that no component on a winch is spec'd for overhead use. Quote:
Go get some sting and your favorite model Jeep; rig this up at home. Simulate reeling in at the front bumper, while keeping the anchor points as in the diagram. You'll see that this is a viable rigging for winching backward. Quote:
I did say (as you mention) ...when you snatch-block it, the load at the pulley is about double the load of the pull. . But then I make the leap (assumption) that Now you're putting 16,000 lbs of load on a cable. I would love to understand this point better. What follows is based on my understanding and assumtions. I don't have enough eveidence to say this is all fact. If anyone has references to material that explains this better, please let me know. I understand that the work done by the winch in a single-block-with-the-end-of-the-cable-attached-to-the-pulling-vehicle is one half the weight pulled. Let's use an example of an 8,000 lb winch, doing a 16,000 lb pull. Load at winch and end of winch cable = 8,000lbs each. Load at anchor point of snatchblock = 16,000 lbs. What is the load on the cable, at the apex of the turn on the block? Some of the strength of the cable will be supported by the friction on the snatch block pulley, but what is the force at the apex? Isn't it 16,000 lbs? As a test of this, I picture this: Take a piece of string, and keep hanging weight to it until it snaps. Let's say it broke at 65 lbs. Take a piece of this same string, hang it from a pulley. Add 60 lbs to each free end of the string. Think it will break? It sure will, because at some point on the pully, the string is feeling 120 lbs. |
#8 |
OK now, talk amongst yourselves...
#10 | ||||||
Brake Wizard
Crosby is one of the most respected suppliers of rigging in the industry. Read about tail chains and apply what they say to what we do and then compare the WLL. BTW- I hadn't read this until I found it. So my use of the 3-1 WLL didn't come from there. Quote:
You've created a scenario to support your flawed premise. Say your winch had a max pull of 60 lbs. Now what?
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#11 | |
In my example, the string fails at 65 lbs (breaking strength just a little more than the 60 lb winch you mention). So now, is it possible to break my 65 lb string (using a pulley system), without ever exceeding 60 lbs of force from the winch? If no point on the string ever has more force on it than 60 lbs, the winch will stall, before the string ever breaks. |
#12 | |
Brake Wizard
#13 |
not to get somehthing started but i want to know how that 8 pully pull worked. i can for the life of me figure it out even with the animation. how are you gonna pull something one way while pulling the opposit way as well?
#14 | |
#15 | |
This web site does a decent job explaining pully principles. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
