Winch cable dampner - Page 2 - JeepForum.com
post #16 of 26 Old 07-15-2010, 02:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Convert to a far safer 3/8" synthetic rope and none of this is an issue.
Jerry Bransford is offline
post #17 of 26 Old 07-15-2010, 03:34 PM
lumpster
lumpster's Avatar
if you have the money to convert to it. a 10 dollar blanket is far cheaper than a 300 rope and aluminum hawse fairlead or at least new rollers so you dont cut the crap out of the new rope, let alone the fact that you might as well get a dafety thimble while your at it, another 60 bucks.
lumpster is offline
post #18 of 26 Old 07-15-2010, 04:00 PM
rikkards
rikkards's Avatar
Plus if you don't intentionally get yourself into a situation where you may be needing the winch but want it just in case, no point in upgrading to a synthetic rope but (as usual) Jerry is right; you don't have the issue of dangerous flying ropes with synthetic.
Machete don't tweet
- Machete
rikkards is online now
post #19 of 26 Old 07-15-2010, 04:38 PM
thatnameisinuse
thatnameisinuse is offline
post #20 of 26 Old 07-15-2010, 08:39 PM
biffgnar
biffgnar's Avatar
Originally Posted by rikkards View Post
To quote the (in)famous BillaVista (who probably got it elsewhere):
The minute you stop respecting this, it kills you
Nicholas Cage in The Rock
biffgnar is offline
post #21 of 26 Old 07-15-2010, 11:01 PM Thread Starter
99_green_tj
Thank you for the replies, it gives me some ideas until I can go synthetic. From what I am hereing I know its not full proof but it will cut down some of the snap in case something does happen......which nobody im sure wants to witness.
99_green_tj is offline
post #22 of 26 Old 07-16-2010, 03:47 AM
rikkards
rikkards's Avatar
First key thing is make sure no one is in between the vehicle that is winching and the one being winched. That way if for whatever reason the blanket doesn't stop it enough the vehicles will act as a barrier.
Machete don't tweet
- Machete
post #23 of 26 Old 07-16-2010, 09:21 AM
mdm
Farm Wheeler
Plus if you don't intentionally get yourself into a situation where you may be needing the winch but want it just in case...
There are some places I routinely go where I know before I leave the house that the odds of needing to pull the cable are %100. I guess I'll just start staying home on those days.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #24 of 26 Old 07-16-2010, 09:43 AM
rikkards
rikkards's Avatar
no need to be a smartass. I was saying that upgrading to a synthetic may not be necessary just use a blanket. If you regularly use it then it is definitely beneficial to upgrade to synthetic. For me, I am not that adventurous (yet) so wire cable and a blanket would suffice.
Machete don't tweet
- Machete
post #25 of 26 Old 07-17-2010, 08:38 PM
DanZ51
I've heard of some using an old inner tube with some sand in it. I'm kinda fond of the mover's blanket though. It's more "multi-purpose" as it gets used more as a off road creeper when fixing stuff and it might keep me from freezing come some winter night
"I will always be an American Soldier"
DanZ51 is offline
post #26 of 26 Old 07-18-2010, 09:58 PM
shotgunsmith
I use a section of old fire hose filled with sand
"If a law is stupid, you have to break it."
HST
shotgunsmith is offline
winch , cable dampner , blanket , alternative , suggestion
What oil for a winch Cable? halltrail TJ Wrangler Technical Forum 11 07-19-2007 04:29 PM
Winch cable Tim Shafer YJ Wrangler Technical Forum 9 07-07-2007 08:16 PM
Winch cable yarosig YJ Wrangler Technical Forum 3 11-26-2006 07:00 PM
Winch cable ?'s RescuedJK TJ Wrangler Technical Forum 10 01-13-2005 08:58 PM
winch cable Jeepin99 TJ Wrangler Technical Forum 1 04-05-2003 09:46 PM
