Winch cable dampner - JeepForum.com
post #1 of 26 Old 07-15-2010, 03:58 AM Thread Starter
99_green_tj
Winch cable dampner
Does any body have any good ideas they use for a winch cable dampner other than the ARB style blanket? I am looking for a good idea that somebody may have to make up something fairly easy and a little cheaper than the blanket. Thanks......
99_green_tj is offline
post #2 of 26 Old 07-15-2010, 05:38 AM
never monday
2 2# diver weights in a loop of nylon webing
never monday is offline
post #3 of 26 Old 07-15-2010, 09:12 AM
19OlllllllO41
19OlllllllO41's Avatar
A "moving blanket" (very thick heavy duty blanket moving companies use), a heavy canvas tarp, or even a heavy jacket like a Carhartt can work.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #4 of 26 Old 07-15-2010, 09:28 AM
BubbaNTx
I Just Hang My tow chain around mine with a couple wraps.
BubbaNTx is offline
post #5 of 26 Old 07-15-2010, 10:27 AM
DevilDogDoc
Doesn't make too much difference what you use anyway as it won't make a difference when that cable let's go....
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #6 of 26 Old 07-15-2010, 10:32 AM
rikkards
rikkards's Avatar
The instance it lets go it will drop 9.8 m/s2. Granted it will still go which ever way it was going to go but since they are usually less than a couple feet from the ground, a good amount of the lashback will be affected. It will make some kind of difference.
Gravity.. It's the LAW!
Machete don't tweet
- Machete
rikkards is offline
post #7 of 26 Old 07-15-2010, 10:36 AM
DevilDogDoc
That may be true but where on the line do you place said weight?
post #8 of 26 Old 07-15-2010, 10:37 AM
mdm
Farm Wheeler
Really? I guess my eyes must have deceived me in the past. I watched a cable snap on an ATV that flew like a bull whip. I've watched another cable with a sleeping bag on it hooked to a F250 break. It whipped less than the on on the ATV.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #9 of 26 Old 07-15-2010, 10:41 AM
DevilDogDoc
Well unless you know where that line is going to break it won't change much, if it is before the break it will drop to the ground, if you place it after it will whip anyway. Now if you have 4 feet of the line payed out and you have a 4 foot sleeping bag covering the line well that might make a difference.
post #10 of 26 Old 07-15-2010, 10:52 AM
mdm
Farm Wheeler
Since you don't know which way another vehicle may come at you as you go down the road, don't bother looking either way as you go through an intersection.
mdm is offline
post #11 of 26 Old 07-15-2010, 11:07 AM
DevilDogDoc
^^^ yeah that's exactly what we are talking about. Throw a 2 pound blanket on the line and you might be lucky and if it makes you feel better. Having been to a rigging yard that broke wire rope the size of your forearm to grade where the breaking strength lay,I would rather take my time and check for kinks and frays and bleeding cores instead. Maintain the line, stay out of the kill zone and winch safely. If a jacket on the line is better than that for you go for it.
post #12 of 26 Old 07-15-2010, 11:08 AM
rikkards
rikkards's Avatar
You put it in the middle, if it breaks on either side the longer portion will be damped. If it breaks in the middle under the blanket both get damped.
Of course you also make sure that no one is standing between the vehicles.
Machete don't tweet
- Machete
rikkards is offline
post #13 of 26 Old 07-15-2010, 11:10 AM
DevilDogDoc
If you say so
post #14 of 26 Old 07-15-2010, 11:17 AM
rikkards
rikkards's Avatar
It's better than nothing.
To quote the (in)famous BillaVista (who probably got it elsewhere):
The minute you stop respecting this, it kills you
Machete don't tweet
- Machete
rikkards is offline
post #15 of 26 Old 07-15-2010, 11:31 AM
DevilDogDoc
And in that we are in perfect agreement! I just don't want anyone thinking that a blanket or weights or anything else is going to save your bacon if you are in the arc if/when that line lets go. I am all about wheeling safely! Respect the tools we use and have a good time!!
winch , cable dampner , blanket , alternative , suggestion
What oil for a winch Cable? halltrail TJ Wrangler Technical Forum 11 07-19-2007 05:29 PM
Winch cable Tim Shafer YJ Wrangler Technical Forum 9 07-07-2007 09:16 PM
Winch cable yarosig YJ Wrangler Technical Forum 3 11-26-2006 08:00 PM
Winch cable ?'s RescuedJK TJ Wrangler Technical Forum 10 01-13-2005 09:58 PM
winch cable Jeepin99 TJ Wrangler Technical Forum 1 04-05-2003 10:46 PM
