Why do I need a locker? I thought I had 4X4! - Page 6 - JeepForum.com
 2Likes
post #76 of 123 Old 02-15-2011, 03:43 PM
NateRomanowski
Thanks for the read, tons of useful info !!!!!!!
NateRomanowski is offline
post #77 of 123 Old 02-15-2011, 04:31 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by cheftrail View Post
about two weeks ago i cashed out my diff in d35, eventually i plan to go with 8.8 but for now i just need it back on the road. i looked at the three reviews for the eaton truetrack and i think i've made up my mind. my question is about the price! in the reviews the msrp is $200, where did this price come from? best price i can find so far is $420 shipped
whoever said the Truetrac goes for $200 was way off, $420 is more is more realistic. A lunchbox locker can go for $200, but not an Eaton (Detroit) Truetrac.
Jerry Bransford is offline
post #78 of 123 Old 03-04-2011, 11:05 AM
ammaar555
http://auto.howstuffworks.com/differential.htm
This is really great.thanks
<a href”
transportation</a> | <a href=”
transport quote</a>
ammaar555 is offline
post #79 of 123 Old 04-10-2011, 09:59 PM
4Tom
I’ve a 2001 Grand Cherokee WJ Quadra Trac II auto box with open diffs front and rear. There isn’t a 2wd or 4wd select. Ive only got full time 4wd or low4wd,
In normal hi mode the rear axle is driven if there is speed difference between axles the front axle is auto engaged. On wet road at speed this is a good thing as it maintains traction on the road but if I fitted an auto locker like the Spartan or Aussie locker it would engage and having a locked diff on frond wheels while in a bend concerns to me.
In Low mode both axles are linked together so locked diffs is ideal and not a problem or concern. This points in the direction of Detroit Truetrac or ARB air locker. I was thinking about fitting to rear axle (dana 35) with LSD and maybe later LSD in front.
Have I got the right take on this or have I missed something ?
Thanks
Tom
4Tom is offline
post #80 of 123 Old 04-25-2011, 08:56 PM
Jeeper69
Originally Posted by Jerry Bransford View Post
When the tires are spinning... which is when you are giving it gas.
but my tires spin when not giving it gas and in 4 low and in first...
Jeeper69 is offline
post #81 of 123 Old 04-25-2011, 09:00 PM
nibstools
you need a locker so you can do this.
Check out "my little YJ" in the Jeep builds section.
http://www.jeepforum.com/forum/f22/my-little-yj-1127802/
nibstools is offline
post #82 of 123 Old 04-25-2011, 09:46 PM
Jeeper69
Originally Posted by nibstools View Post
purty sweet mayun
Jeeper69 is offline
post #83 of 123 Old 04-26-2011, 07:16 AM
Gainer
shouldn't have watched those video's.... gonna cost me some big $$$$.$$
Gainer is offline
post #84 of 123 Old 04-26-2011, 07:23 AM
nibstools
Heres a couple more.
post #85 of 123 Old 06-04-2011, 09:03 PM
Fireshot151
Originally Posted by Car RamRod
thats new to me.
Im gonna have to try it.
Originally Posted by XJHERO
Very interesting. my question is will manual lockers still unlock in a turn or will you have to manually unlock them and then re-lock them when you straighten back up. I want to put a set of lockers in my XJ but unfortunately its my daily driver so auto locker probably wouldnt be the best bet due to much more street driving than off highway.
Manual lockers: I have a dana 44 with an ox locker. I've found you don't want this engaged on the pavement AT ALL. Once your on dirt you can have It engaged all the time if you want. I say this because the dirt or gravel will allow the axles to slip a bit when cornering. On paved roads this would be a violent hoping motion.
Fireshot151 is offline
post #86 of 123 Old 06-29-2011, 05:56 PM
mbrennan93
Thanks, got a few gears turning in my head too though.
How are the manual lockers locked in? Linkage or a switch? Are there any mods to the rear to accommodate?
mbrennan93 is offline
post #87 of 123 Old 07-17-2011, 09:15 AM
OregonVette
Thank you for the great post Jerry!
Say, in regards to many of the newer JK owners, the most modern JK has an outstanding BLD, ESP, Dana 44 rear and some (most Saharas) come with TracLok. Your OP was written before the new JK came out. If I could just add a few things so newer jeepers just don't run out & buy a new locker which may be unneeded.
After just completing the Naches Trail run, you'd be surprised at how capable, flexy, and downright awesome the most modern JK is. Granted, I'm old enough to remember having to go outside and "flip" the hubs to get them locked, i wholeheartedly appreciate fully locked rigs but...
Before this last 5 day adventure tour, I was certain I was going to add ARB air lockers to the Four door JK Jeep. Nope, again I was thoroughly impressed at how well these three components work together (all JKs have a D44 rear):
1. Traclok
2. ESP
3. BLD
Plus, adding front sway bar disconnects will keep the front two tires on the ground, where they belong even in the most funky off-camber pucker inducing event.
I will not be adding air lockers to the JK after all.
At the end of every day, all the old-timers in their flat fenders and even many of the youngster in their TJs would come over and look at the JKs and say how impressed they were & how they were certain the new JK could never keep up etc... Once they get towed out by a "mini-van" their tune changes a bit!
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #88 of 123 Old 08-18-2011, 10:21 PM
hrt4me
Originally Posted by ammaar555 View Post
very informative to us novices
hrt4me is offline
post #89 of 123 Old 09-05-2011, 06:16 AM
Deuskid
newbie subscription
Deuskid is offline
post #90 of 123 Old 09-05-2011, 06:22 AM
nibstools
Mine is the one not stuck driving in the back ground. aussie lockers front at rear 34x9.50 swampers. That mud is very deep!
What? Why do I need a locker? I thought I had 4WD! Jerry Bransford Engines & Drivetrain 69 07-07-2017 06:28 PM
How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle. CanukYJ Fabrication Shop 107 12-04-2011 07:14 PM
Stock front locker with Detroit rear locker wiring question RallyeX Engines & Drivetrain 2 06-13-2011 11:45 PM
front locker vs rear locker. ms198 Engines & Drivetrain 7 01-14-2011 01:44 PM
Front locker vs. rear locker airtraffic007 Engines & Drivetrain 16 04-09-2008 11:04 PM
