#1 | |
Who is running air compressors?
Just curious how many of you run on-board air and how you set it up/where you mounted the tanks? Pics would be SWEET! Any recommendations on what tank to run? At the moment I'm looking to be able to re-inflate my tires when I get off the trail with it.
Thanks, Josh ![]()
Owning a Jeep makes a heroin addiction look like a vague yearn for something salty... 2002 Inline 6 TJ-X 4.0, D30/D35 w.4:56s 2inch BDS Full Coil Suspension, Incubus 511 Rims, 33inch Mickey Thompson ATZ, Bestop HighRock Front (w/Stainless Grill Guard) and Rear Bumper, KC SlimLites, Custom "TJ" Tail Light Covers When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of! : ) |
#2 |
I have the ARB. It works fine for airing up and down your tires. It takes 5-7 min per tire. My tires 39.5x15x15's air from 6 lbs to 18lbs in about 7 miniutes per tire. I never have to let to cool down either, but I always check to fitting to see how hot it gets.
I looked for pictures and didn't find any good pic's of the ARB, but if you look at the top of this pic you can see where the ARB air is mounted. ![]() I hope it helps. By the way.. If you get the air compressor. you are can use it for you lockers later.
97 Jeep: 5.0 HO,13"lift, 39.5" Swampers, Air Lockers, 4.88's, Disk Brakes, 9500 Lbs Winch, recovery tools . Last edited by Rock Dawg 97124; 07-14-2008 at 05:37 PM.. |
#3 |
I use the Puma air compressor.
![]() I separated the compressor from the tank and mounted it on the ABS tray sorta/kinda. ![]() The tank is under the Jeep. ![]() Works very well. Bob
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#4 |
#5 |
I run a Viair 460C mounted vertically over the driver side battery tray.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#6 |
I have an ARB compressor for my lockers but wanna get one so i can run train horns, air tools maybe, but most of all inflate tires!! The thing i dont understand with them is how to get the to run the air lockers??
#7 |
i have a q-maxx air compressor i got from costco for $49 that hooks to the battery and inflates my 33s from 12-30psi in a few minutes
it's not the quickest in the world and can't run air tools but i can't complain for what i paid for it |
#8 |
Jeepaholic
I run a sanden for my lockers, tools, and to air up tires. Only takes a few minutes to air up all 4 35's from 8 to 25psi since I use a quadraflate type thing that I built. My bumper is my tank. you can see my compressor as well as my tank.
#9 | |
Dumb question, why use your bumper as a tank? I ask as there are some inherent problems. Without coating the inside ~ it will rust and rust will flake, passing rust particles/flakes throughout your system. Potential Problem. Airtanks are pressure tested, meaning they will take alot before blowing apart like a hand grenade. A bumper would not be. Same token the same bumper takes a hit (tree, other jeep) another potential problem. It works for you, awesome, just curious thats all. I hope you dont have these problems... Sorry just curious.. Cheers ![]() ![]() |
#10 |
Look into the MF-1050. A couple of months ago there were many available on ebay, now there doesn't seem to be any, at least by my hasty search. Some people have found them for around 50-75 at pep boys and the likes.
http://www.parksoffroad.com/prodreview/inflatortest/superflowviaircomparison/superflowviaircomparison.htm I got mine on ebay for ~35 a piece shipped, no joke. They were so cheap i bought multiple so I could build an on board air system with 2 or 3 of them for redundancy. They have more than lived up to my expectations, and really seem to perform as well as some others that cost 10x more. -Brent
- 06 LJ Rubicon 34" LTB's / 33" MTZs, OME Springs/Shocks, RE FTB, JKS RTB & 1.25BL, Brown Dog MML, Fabtech F Bump, Warn M8000 on AtoZ plate, ORF R Bumper & Rack, AR CAI, Banks Catback, Hi-Lift, Midland 75-822, Dual MF1050 Comp, Clayton Skids, Kilby Gas Skid - 94 Firebird Formula, 02 Softail Deuce, 86 GSXR750 - RIP 97 TJ, 83 CJ7, 87 TType |
#11 |
Jeepaholic
The bumper was built as a tank by bulletproof engineering as a tank and I never really run it much above 150 psi and the whole system does have a pop off valve; also the air comes in thru the top and comes out thru the top o the other side plus I have a drain **** on the bottom of the bumper. As for reliability its been on there for almost a decade with no problems and some oil does slip by the oil filter and maybe it coats the inside but never makes it out
of the air line. Also it's convenient for me. |
#12 |
I run a cheapo Superflow MV50. Works awesome, no tank. Takes about 3 minutes/tire to go from 8 to 28 psi, on 31's.
I want to add a 2 gallon tank to it though. Cost me $140 or so CDN.
(O|||||||O)
l_l*-----*l_l Raskull - Metallic Silver '03 Jeep TJ Sport (pic) http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery Custom front bumper build Custom rockers build My build thread |
#13 | |
and using an air/water seperator (like you should on any air tank) will prevent most humidity from entering your tank.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci Last edited by Greg_Volkman; 07-15-2008 at 10:42 AM.. |
#14 | |
A bumper is a great place to put an air tank. It doesn't need to be coated on the inside, especially if you've got an oiler or dryer setup on the pump. It should have a blow off valve and a pressure limit valve with a max between 125-175psi. The yeild strength of mild steel is 75,000 psi. Only time it would possibly become damaged would be in a BAD accident with a semi truck, and it wouldn't 'explode' with shrapnel everywhere, it would rupture on along a stress fracture and all the air would exit in a fraction of second, making quite a lot of noise, but no catastrophic destruction.
#15 |
Just as an alternative -
I almost put onboard air in, but found a twin cylinder compressor that works real well. My aired down 33" swampers usually take less than two minutes to re-inflate. $170 : http://www.jcwhitney.com/autoparts/Product/Pr-p_Product.CATENTRY_ID:2012885/c-10101/Nty-1/p-2012885/Ntx-mode+matchallpartial/N-10101/tf-Browse/s-10101/Ntk-AllTextSearchGroup?Ntt=air+compressor Steve
======================= 04 Unlimited 4.5" RE long arm, 1.25 JKS body lift, 35" Coopers STTs (And some boggers soon), skid row oil and steering box skids, warn 9000i winch, skidrow nightcrawler front bumper, hanson rear bumper w/ A frame tire carrier, shrockworks rocker protection, SYE, CV Driveshaft, ARB diff covers, Currie tie rod system, KC lights, CB, and tons of other stuff. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
