Where is the Best Place to Mount A High Lift??? - JeepForum.com
post #1 of 18 Old 03-07-2012, 05:01 AM Thread Starter
KING91YJ
I WANNA SEE WHERE YOU PUT YOUR HIGH LIFTS AT! SHOW ME A PICTURE!
KING91YJ is offline
post #2 of 18 Old 03-07-2012, 05:04 AM
austin6137
1990 XJ Cherokee
http://www.jeepforum.com/forum/f46/h...hlift+mounting
Welcome and here you go
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #3 of 18 Old 03-07-2012, 05:49 AM
1998zj
In the corner of my garage, right where it belongs.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #4 of 18 Old 03-07-2012, 11:26 AM
92 Green YJ
92 Green YJ's Avatar
Here is the new mounting location for mine
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 18 Old 03-07-2012, 04:57 PM
XJohnnyC
XJohnnyC's Avatar
That's where mine has been for the past few years.
I finally got rid of it a couple of weeks ago.
XJohnnyC is offline
post #6 of 18 Old 03-07-2012, 07:05 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My Hi-Lift provides a home for my backyard shed's resident black widow spider. I stopped carrying it on my Jeep years ago. I used it twice to try it out but found it is more dangerous than it is worth and so seldom really needed that I soon figured out it was more weight and trouble than it was worth.
And I don't care if you have 35" tires, you don't need a Hi-Lift to change them... the factory jack works just fine for them.
Gone on vacation until August 25.
Jerry Bransford is offline
post #7 of 18 Old 03-07-2012, 07:43 PM
BlueRubiconrich
Don't mount it out side.Mount it inside.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #8 of 18 Old 05-24-2012, 06:12 PM Thread Starter
KING91YJ
thanks for the help guys!
KING91YJ is offline
post #9 of 18 Old 05-25-2012, 08:46 AM
Ross
I mount mine across the back behind the roll bar, strapped down. It serves two purposes for me, the occasional actual need for this type of jack and to hold my crap down in the back when I tip the jeep over. I have a sub woofer, 12 volt air compressor, strap, shackles and D rings in the back. Everything is packed in a way that the can't fall out when I lay my jeep over. I have tested this 3 times (just laid over on the side) to date and have lost nothing out of the back.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #10 of 18 Old 05-25-2012, 10:00 AM
BleepinJeep
1988 XJ Cherokee
Apparently this is the best place as it protects you from rollovers:
Website -
- The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube -
- Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline
post #11 of 18 Old 05-25-2012, 02:48 PM
rjbruzan
I took mine apart and bolted the 48" upright on top of my rear bumper laying flat. The base and jack mechanisim ride in a small bag behind the rear seat.
I run the sand dunes and a tall jack comes in handy. I will say I've used it more for others than my self.
Ron
rjbruzan is offline
post #12 of 18 Old 05-26-2012, 09:27 PM
loganm
What's he big deal with mounting it outside? Besides dirt and stuff which can be washed off and cleaned is there really anything I'm missing? My next big purchase is going to be jeeperman rear bumper which comes with high lift mounting. Which is where I wanted to put mine!
loganm is offline
post #13 of 18 Old 05-27-2012, 03:30 AM
1222
RIP John
1222's Avatar
I have a brand new one taking up space in my garage that I bought over 20 years ago. I never mounted it on any of my Jeeps and never will.
OP, wherever you mount it don’t mount it to your front bumper. A friend of mine did that to his TJ some years back and bent it the very same day.
1222 is offline
post #14 of 18 Old 05-27-2012, 06:44 AM
1998zj
Uh, rust?
1998zj is offline
post #15 of 18 Old 05-27-2012, 12:10 PM
HooliMcGee
Anywhere but the hood!!! I'm far from a safety N***, but it's one thing I cannot understand when it comes to offroading mods. It's a recipe for some facial plastic surgery, that is if you survive. Even things set on the dash in a hard frontal impact can do some serious damage.
My underlying principle is that, as the driver, you make the choice to put the vehicle in precarious situations. You can take the responsibility for the amount of risk you put yourself in behind the wheel, but it's wrong to put a passenger in the line of fire.
I won't ride in a Jeep with the Hi-lift on the hood, not even to run to the grocery.
If you must have it, the front or rear bumper is the way to go
HooliMcGee is offline
XJ high lift mount XJKyle1389 Fabrication Shop 2 11-21-2008 06:53 AM
high lift mount Okie05Unlimited General Jeep & Off-Road Equipment 17 08-26-2007 01:24 PM
Where's the best place to mount a CB Jeepchick953 Audio, CB & Ham Radios, GPS, & Electrical 42 02-26-2007 04:12 PM
TJ high-lift mount UTmike Cheap Tricks & Fixes 2 04-06-2006 12:43 PM
Best place to mount an Amp in a YJ?? evilpsych Audio, CB & Ham Radios, GPS, & Electrical 11 11-13-2001 01:03 AM
