When to air down, and when not to? - JeepForum.com
 2Likes
post #1 of 73 Old 07-18-2011, 02:41 PM Thread Starter
clg82
Hey everyone. When do you air down and to how much? What is wrong with running with the stock tire pressure, say in rocks (sharp ones) or while climbing thru mountains and valleys? And how do you re-air when you are done wheeling and about to drive home on the regular road?
clg82 is offline
post #2 of 73 Old 07-18-2011, 02:54 PM
wushaw
Rockin jeep
wushaw's Avatar
Air down for trails you plan to run. 8 - 10 psi for me. I have OBA for air so I can air up anytime.
wushaw is offline
post #3 of 73 Old 07-18-2011, 02:56 PM Thread Starter
clg82
So any trails?!?!? sand or sharp rocks? I won't pop a bead at 8-10 psi?
clg82 is offline
post #4 of 73 Old 07-18-2011, 03:06 PM
CrawlingForward
There's a lot of different factors that determine what PSI you can go down to, but you're usually pretty safe down to at least 12psi.
You should always air down when wheeling. The miniscule amount of ground clearance you lose is more than made up for by superior traction and lack of bouncing which keeps your wheels in better contact.
From a Leave No Trace perspective, it's the responsible thing to do *every* time out because it prevents wheelspin and tearing up trails.
If it's a mountain road, you don't really need to worry about it, but basically anytime you're going to be using 4-Lo, it's a good idea.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #5 of 73 Old 07-18-2011, 03:23 PM Thread Starter
clg82
Even thru sharp rocks and rugged terrain?
clg82 is offline
post #6 of 73 Old 07-18-2011, 03:32 PM
CrawlingForward
I would think especially on sharp rocks at low speeds. The concern, as I understand it, is for your sidewalls. Airing down would probably help the tread, as it lets it conform instead of just puncturing.
However, at higher speeds I've heard a lot of debate, but I don't air down at higher speeds anyhow.
If it was so sharp and pointy that your sidewalls would be in danger, I would assume that they would be in trouble either way, but someone with more knowledge may pipe in.
post #7 of 73 Old 07-18-2011, 03:36 PM
iDriveYJ
I hear airing down in mud gives you much better floatation and traction haven't done it yet but I will my next go around.
iDriveYJ is offline
post #8 of 73 Old 07-18-2011, 03:40 PM Thread Starter
clg82
Mud is not my concern as there is very little of it in the desert...........But sharp rocks etc are a different story.
clg82 is offline
post #9 of 73 Old 07-18-2011, 03:43 PM
Green4dr
if your doing real basic stuff you really dont have yo air down at all. So far i havent aired down ever but i mostly do shallow mud and very little rocks and stuff. so if your not wheeling very seriously dont worry about it.
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
post #10 of 73 Old 07-18-2011, 03:58 PM Thread Starter
clg82
Some of my wheeling can become serious rock ledges etc, very sharp rocks at times bigger rocks etc..
clg82 is offline
post #11 of 73 Old 07-18-2011, 04:11 PM
wushaw
Rockin jeep
wushaw's Avatar
"I" won't pop a bead at 8-10psi, I have bead locks that's why I said it was good for me.
12psi like Crawling forward said sounds good for non-bead locks on rocks.
wushaw is offline
post #12 of 73 Old 07-18-2011, 04:25 PM Thread Starter
clg82
Ok sorry I misunderstood you...I didn't know that you had beadlocks....
clg82 is offline
post #13 of 73 Old 07-18-2011, 04:28 PM
danielbuck
1946 CJ2
me, I air down anytime I'm going to be offroad for more than 10 minutes or so. It takes me about 10-15 minutes to air back up (I don't have an air tank, so it's slow with my 12 volt air pump), so I don't air down unless I'm going to have time to enjoy being aired down to make the 15 minute air-up time worth waiting for, haha! So if I'm just going offroad real quick to get to like an overlook or something to take photos, I won't air down, but if I know I'll be offroad for a while and driving slower than 20mph or so, I'll air down.
Traction is helped yes, but man the ride quality is MUCH smoother when you air down, it's just more enjoyment when the ride isn't so jaw-breakingly rough even on small rocks when aired up to street pressure. I don't know what PSI you need to drop to before you start getting a nice smooth ride, but before my beadlocks when I was at 12-14psi the ride was noticably smoother, and now at 8-9psi with the beadlocks it's nice and smooth. I suppose even dropping 5-10psi would be smoother than leaving it fully aired up. But the lower you go, the smoother the ride. Even on trails that I don't need the additional traction, I'll air down just for a ride comfort factor.
danielbuck is offline
post #14 of 73 Old 07-18-2011, 04:35 PM Thread Starter
clg82
How much and what kind of bead locks do you have if you don't mind me asking
clg82 is offline
post #15 of 73 Old 07-18-2011, 05:00 PM
danielbuck
1946 CJ2
mine are from Champion, I think they were almost $300 per wheel with all the hardware included. You don't need beadlocks to air down, you can just air down farther with more confidence on the beadlocks. Try airing down to about 12 or so, see how you like the ride quality, it should be noticably better than when not airing down. (I'm on 32" tires right now, by the way)
Here they are at 12, and 8 psi. The tire doesn't bulge out that much on flat ground.
