Wheel Spacers??? How do you guys feel about them? - JeepForum.com
post #1 of 17 Old 04-10-2011, 07:35 PM Thread Starter
JCMathis
Myself and a few of my friends have a interest in Wheel Spacers. However each of us disagree's as to their worth. I personally believe that although they can help to fill out those wide flares, they can also be potentially more deadly to your wheel bearings.
How do you guys feel? Have you had good experiences, or bad? What brands do you feel are quality?
Alright...play nicely....
JCMathis is offline
post #2 of 17 Old 04-10-2011, 08:07 PM
Ryman12
Well heres my opinion on them. Wheel spacers are more dangerous simply because you now have twice as many lug nuts you need to tighten down. If you dont meticulously tighten each one it could loosen up without you noticing. As far as the damage caused to the hubs go, it is just the same as using a rim with less back spacing. Either way the hub is going to be put under more strain. If you are trying to accommodate wider tires then I say its a necessary evil, but if you just want to push your stock tires out farther I say it probably isnt the best of ideas.
2000 4.0 wrangler 2.5" lift
5 speed JCR Off Road prerunner bumper
Ryman12 is offline
post #3 of 17 Old 04-10-2011, 09:19 PM
Wearingthin
That's what lock tight is for
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #4 of 17 Old 04-10-2011, 10:00 PM
92 Green YJ
92 Green YJ's Avatar
I've never run them or run with anyone who has, but personally I wouldn't use them. I just don't feel they are all that safe in the long run. it puts more force on the bearings and studs, potentially more force on the suspension as well (though on that i guess full widths would too so thats probably a moot point). Also as stated its that much extra maintenance to remember to do. I just don't think i could ever bring myself to trust them. and definitely not on a front application. I could see all sorts of issues with the steering, stock unit bearings, tire wear, etc
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 17 Old 04-10-2011, 10:38 PM
WhiteOut
WhiteOut's Avatar
Using good wheel spacers (Spidertrax) is no different than using differently backspaced wheels. The spacers get bolted to the stock lugs, red locktite and then torqued to spec. The wheel is attached to the lugs on the spacer. The same force is applied to bearings and components as would be applied with a differently backspaced wheel. There is zero extra maintenance to do since checking torque will break the locktite and you have to start over again.
I have had zero issues with mine, never checked the torque after the initial install, no issues with loosening or having alignments or anything else done.
WhiteOut is offline
post #6 of 17 Old 04-10-2011, 11:23 PM
tehgregzor
It seems the consensus is only buy them if you NEED them. Having them on for show does no good. If it ain't broke, don't fix it.
tehgregzor is offline
post #7 of 17 Old 04-11-2011, 06:16 AM
mdm
Farm Wheeler
How do you feel about running wheels with less than stock back spacing?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #8 of 17 Old 04-11-2011, 07:49 PM
mrfast
Same here, and I use spacers from Rough Country! Going on 2 years now.
mrfast is offline
post #9 of 17 Old 04-12-2011, 01:34 AM
RogueSpear2023
There really a non issue if installed properly, some shops won't install wheels if you have spacers. IMO spacers are fine on a jeep, but I would not use them on a heavy duty truck that routinely carries heavy loads, I know when I owned a super duty it was a big issue to not use them, but on most vehicles it's a non-issue.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #10 of 17 Old 04-12-2011, 04:13 AM
Nasmith1
Where I live the big tire shop will not touch a vehicle with spacers, but I know them so they marked off-road use only in the computer
I bought my jeep with wheel spacers and wider flares... didnt even notice until I got home. I knew that jeep looked good though. I want to take them off because the extra width ruins my fitting on four wheeler trails and I have had to replace so many things to make it not have death wobble after I lifted it. I believe these parts wore prematurely due to the spacers, but im still running them because It dont have the money for tube fenders and It looks really funny with them off.
I would never buy them, but im running them. Locktite has not let me down yet.
3 xj's - 1992 k2500 diesel - 1992 corolla (doubled my money..... after I blew it up) - 1995 yj - ***1997 Jeep TJ***
Nasmith1 is offline
post #11 of 17 Old 04-12-2011, 06:03 AM
98zjkidd
I wasn't sure about spacers either but I have a buddy that has an 05 duramax 2500 with 41 irocks 12" lift and everything banks pushing about 600hp and 1100lb and he has ran spacers for over 4 years now no prob this is also his work truck that he hauls his landscaping equipment with
98zjkidd is offline
post #12 of 17 Old 04-12-2011, 03:00 PM
03WJDave
2003 WJ
I ran 2" wheel spacers on My Super Duty with 41" IROKs and air lockers front and rear with no issues. Ran them for 6 years. If installed properly and checked from time to time they are not a problem. One thing they will do is put more stress on front wheel bearings on a big heavy truck like I had and can shorten the life of bearings. Put them on properly with loc-tite and torque per specs.
Member NCBBA, OBPA Join Jeepfishing surf group
Mayhem lives at 1600 Pennsylvania Avenue
03WJDave is offline
post #13 of 17 Old 04-12-2011, 03:40 PM
mrfast
Just kinda thinking out loud, but I wonder with spacers and stock wheels, versus aftermarket wheels with a lot of offset, makes any difference on wear and tear of suspension components?
Like I posted earlier I'M running the spacers with stock Rubicon wheels with 35's for almost 2 years now and aprox 15,000 miles with no ill effect so far, and yes I do go off road about once a month.
mrfast is offline
post #14 of 17 Old 04-12-2011, 05:27 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
The suspension issue is non existent, unless you stuck 6" spacers on each side. There is no way a 1.5" spacer/adapter could make that much of a difference to the suspension via its marginal extra leverage.
I run them on my JK Rubi axles, to allow me to run 5 on 4.5 wheels, which are everywhere and cheap. Never had a single issue.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #15 of 17 Old 04-12-2011, 08:41 PM
heisman01
2015 JK Wrangler
Ide only recommend them if your trying to run 14"+ wide tires and not use new axles or buy new rims to avoid rub issues
heisman01 is offline
wheel , wheel spacers , wide
wheel spacers jeeperz258 Tires & Wheels 2 11-19-2010 09:37 AM
wheel spacers tjg1491625 Tires & Wheels 2 09-01-2010 05:02 PM
Small wheel spacers? Do you guys trust them? MA88XJDude Tires & Wheels 4 04-12-2010 09:58 PM
???'s about wheel spacers claytonandson Tires & Wheels 3 12-27-2009 03:52 PM
wheel spacers allaboutjeep Tires & Wheels 5 02-18-2003 12:11 PM
