What's the diff? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > What's the diff?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 02-12-2003, 07:29 PM   #1
ILoveto4x4inNC
What's the diff?
I have what is probably a stupid question. What's the differance between a Dana44 and Dana44a? I keep reading that you can't do much with one as far as gears and lockers. Is this true? If so why not? Aren't all Dana44s the same? I wouldn't think that it would matter if the center section was aluminum or steel. Somebody please explain this to me.
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline   Reply With Quote Quick reply to this message
Unread 02-12-2003, 09:33 PM   #2
SamFromCO
The 44 and 44a are completely different. The 44a is a c-clip type axle and uses a crush sleeve. I don't believe that any parts interchange. I have no idea why they named the 44a after the famous 44.
SamFromCO is offline   Reply With Quote Quick reply to this message
Unread 02-21-2003, 10:44 AM   #3
ILoveto4x4inNC
I thought that all Dana44s used c clips. Since I don't wheel my ZJ other than to go hunting I don't really need lower gears, but would like to have a selectable locker. Is there anybody that makes a selectable for this rear end?
'98 ZJ with 5.2L
swapped in NV231
Unread 02-21-2003, 11:05 AM   #4
93jeepyj2.5
I always thought that all D44's didnt have c-clips.....never heard of a D44a???
-Heath
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2003, 11:31 AM   #5
CSP
The aluminum housing Dana 44 used in ZJs/WJs is the 44a. It is the only Dana 44 to use c-clips. There are other aspects to it which make it weaker than the standard 44.
CSP is offline   Reply With Quote Quick reply to this message
