What's behind your rockers? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > What's behind your rockers?
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 02-06-2006, 07:39 AM   #1
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
Picked up my AtoZ Fab rockers over the weekend and installed them. When I picked them up from Zach, there was a pretty beefy Jeep sitting in his garage with some sort of black gasket material where the rockers would be, holes were drilled, etc... Which I don't have and didn't put anything between my rocker and the body.
Suggestions for what should go in there? After driving in some rain, I got a bunch of dirt and small stones lodged in the top where the rocker meets the body.
Pimptiva.com
SimonTuffGuy is offline   Reply With Quote Quick reply to this message
Unread 02-06-2006, 09:54 AM   #2
175MM BULLDOG
175MM BULLDOG's Avatar
I applied a whomp of paste wax on the Jeep, not buffed. Then used gaskets made from HomeDepot shower tub liner between the rockers, and Jeep. Then applied a bead of electronic grade RTV along the top of the rockers. I feel that this will keep out the sand & water.
Gun control: "The ability to hit your target"
175MM BULLDOG is offline   Reply With Quote Quick reply to this message
Unread 02-06-2006, 10:54 AM   #3
de6w6it
^ Sounds like you went above and beyond, that is definitely going to be a great seal there....I wish I had gone that far, all I did was smear silicone on the inside surface of the rocker where it was going to meet the body, then ran a bead along the top edge of the rocker once they were installed.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:http://www.yotatech.com/f191/de6w6it...-lemon-190657/
de6w6it is offline   Reply With Quote Quick reply to this message
Unread 02-06-2006, 11:00 AM   #4
SimonTuffGuy
[I'm That Good]
Sounds good. I figured it would just be some sort of silicone sealant along the edges where it meets the body, but I wasn't 100% sure.
Looks like I'll need to break them loose again so I can get something in there to prevent that stuff.
Thanks!
Pimptiva.com
Unread 02-06-2006, 02:01 PM   #5
MuddyV8YJ
2 paths to take, either seal it up super tight so nothing can possibly get in, or leave it wide open so anything that gets in can get out.
the worst is sealing it up like 80%. water will get in, but not be able to get out.
'91 YJ. Slightly Modified
'04 WJ. Columbia Edition 4.7 HO. 2" BB, 2" OME. 265/65/16 Icelander MT
MuddyV8YJ is offline   Reply With Quote Quick reply to this message
Unread 02-06-2006, 03:41 PM   #6
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Another thing to think about is on the underside to use the window and door expanding foam (less expansion that regular expanding spray foam) to keep mud and other crap out from between the body and slider. Run fuel lines and brake cables in some PVC conduit, makes replacing them really easy later on. plus makes clean up a breeze after bein in the mud.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote Quick reply to this message
Unread 02-06-2006, 07:08 PM   #7
CNY
I have Rubicon rocker guards, that came with a rubber gasket that is about 1/8" thick.
Tough Stuff products make something similar, but I here the shower liner stuff is good, also.
CNY is offline   Reply With Quote Quick reply to this message
Unread 02-06-2006, 09:34 PM   #8
method84
i used some foamy type gasket material that we use at work to insulate the low side on AC piping to take temperatures. Its foamy on the outside and has a sticky backing. I think its working out good so far. i havent taken off my rockers since I put them on a few months ago
method84 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2006, 10:54 AM   #9
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
Just a word of advice, I thought you were talking about the rockers INSIDE of the engine. Might want to clarify in your post haeding next time.
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2006, 11:10 AM   #10
SimonTuffGuy
[I'm That Good]
If I was talking about my engine, I would've put this thread in the off-road engine section...
Pimptiva.com
Unread 02-08-2006, 01:50 PM   #11
175MM BULLDOG
Thanks!
Get electronic grade silicon RTV. It does not use acetic acid to cure. I would not want acid against the panels.
Unread 02-08-2006, 08:34 PM   #12
heavyhitter
rubber roofing works
Awesome flyfishing pics and vids here [url]www.fliesandfins.com[/url]
93 YJ almighty 4banger, 31" bfg all terrains on 15x8 ar black steelies, 1.25" PA shackle lift, pioneer stereo system, herculined tub, TJ Flares, Rock Sliders, custom front & rear bumpers,
heavyhitter is offline   Reply With Quote Quick reply to this message
Unread 04-13-2009, 09:59 PM   #13
green89yj
I used home wrap on my hardtop rails and will probably use it on rockers when I get them.
Build
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline   Reply With Quote Quick reply to this message
Unread 04-14-2009, 07:30 PM   #14
lupinsea
Good ideas on the other materials.
When I put mine on I also used the Tough Stuff Rocker Guard Gasket.
It may seem a bit pricey but it has a self-adhesive backing so it's easy to apply and stays put when out put it on the back of your rocker guards. Then just zip an exacto blade around the perimeter to trim to fit. Viola. Nice rubber backing to the rocker guards that stays put. Very easy to then install the rocker guards.
- Jay
lupinsea is offline   Reply With Quote Quick reply to this message
Unread 04-14-2009, 08:42 PM   #15
1996BlackXJ
What's behind my rockers?
Rust
-Max Black 1996 XJ Build Thread: My Maine-iac XJ part deux
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
www.maine4x4.org Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline   Reply With Quote Quick reply to this message
