What's an 85 Mail Jeep Worth? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > What's an 85 Mail Jeep Worth?
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Ford Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim
Unread 02-22-2003, 07:54 AM   #1
GEAH
1974 CJ5
Like the title says whats it worth. Does it have anything in I could use on my YJ? Whats the axel widths? I seem to remember reading that they had locked difs? Yes/No?
Red 90 YJ
GEAH is offline   Reply With Quote Quick reply to this message
Unread 02-22-2003, 12:31 PM   #2
TroyBoyM
whatever
Probably not a lot unless it has some sort of historical value. My grandfather retired from the postal service and he said the postal jeeps took terrible abuse. They were driven by people who treated them like gov't property and not their own and while they had low mileage when they were auctioned off, most of the time they sat idling. I'm not sure how much of it you can use on a YJ. I recently saw a 02 or 03 right hand drive TJ delivering the mail...
TroyBoyM is offline   Reply With Quote Quick reply to this message
Unread 02-22-2003, 08:18 PM   #3
macb
about $20...I will put it in the mail right away!
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah: [URL]http://www.sajeeps.com[/URL]
[url=http://www.cafepress.com/H2RT]No Bling - H2 Recovery Gear[/url]
Bob Supplee:supplee@ionet.net or (405) 799-8977
Stu Olson's great jeep resource site: [url=http://www.stu-offroad.com]www.stu-offroad.com[/url]
macb is offline   Reply With Quote Quick reply to this message
Unread 02-22-2003, 09:54 PM   #4
CSP
First of all a mail Jeep (DJ actually) is two wheel drive. That pretty much rules out using the axles. The rear axle is much narrower than a YJ. No Jeep came out of the factory with a locked diff. Limited slip yes, locked no. The DJ's did come with a limited slip.
CSP is offline   Reply With Quote Quick reply to this message
Unread 02-23-2003, 09:51 AM   #5
GEAH
1974 CJ5
Thanks,
Sounds like a waste of time even going to look at it.
Red 90 YJ
