What winch to buy? - Page 3 - JeepForum.com
post #31 of 33 Old 11-23-2011, 02:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Heat is only an issue when a winch is running in reverse and is using its brake to let a vehicle down an obstacle or cliff. In normal use of a winch when you're pulling yourself towards something, or something towards you, no brake heat is generated inside the drum. The heat issue some worry about is only a theoretical issue and not an issue at all in normal winching.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #32 of 33 Old 11-23-2011, 08:44 PM
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by SolarOne View Post
Good to know, any issues with heat particularly the drum? IDK if I should buy the 9.0 and upgrade to synthetic rope. Or spend the extra money on a Talon SR. Superwinch claimed to have a thicker drum to protect synthetic rope from heat on the EP/i series. IDK if thats true, necessary, marketing or other wise. I was to slow to make up my mind and missed a decent deal for a 9.0S
I have 50' of 3/8" synthetic line where there was 100' of steel. All I can say is it has worked just fine so far on three pulls....2 pullin my jeep and 1 pullin another up a ledge the had a busted axle u-joint.
wushaw is offline
post #33 of 33 Old 11-23-2011, 10:25 PM
kashoggio
Warn has synthetic lines now with their winches. I ordered mine few weeks ago and the tracking says it will be here Monday will post some pics then.
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
Synthetic winch line q's and general winch questions. AlanZ General Jeep & Off-Road Equipment 19 07-31-2011 05:37 PM
Convert a standard Warn XD9000i Winch into a 'Multi-Mount' front/rear easy swap winch awalp General Jeep & Off-Road Equipment 14 03-31-2011 09:12 AM
Rugged Ridge 8500lbs winch or Smittybily 8000lb winch HighRoller02TJ General Jeep & Off-Road Equipment 5 05-20-2010 12:45 PM
Which winch plate is flat to frame and will hold my winch close to grill? CB3 General Jeep & Off-Road Equipment 5 02-23-2010 08:23 PM
brush guard, winch, winch mount compatibility Longspoon General Jeep & Off-Road Equipment 6 07-25-2007 12:48 PM
