What? Why do I need a locker? I thought I had 4X4! - Page 3 - JeepForum.com
post #31 of 115 Old 05-28-2009, 10:39 AM
RaggedOleMan
Finished Hand Throttle Installation
Here's the Rubicon Exress Hand Throttle (installed) in my 2005 X...
RaggedOleMan is offline
post #32 of 115 Old 06-23-2009, 05:28 PM
goalieman1830
thanks for the awesome post. just bought my wrangler yesterday so the more i learn the better
goalieman1830 is offline
post #33 of 115 Old 07-07-2009, 09:20 AM
dirt_pirate
that was a lot of good information for a newbie such as myself. It explained a lot I didn't understand
dirt_pirate is offline
post #34 of 115 Old 08-06-2009, 10:51 AM
mchs2009
i learnd a lil trick which most of you probly already know but if you dont have lockers like me just hold the brake a lil when you lose traction with one tire this locks up the loose tire and tricks the stock diff
mchs2009 is offline
post #35 of 115 Old 09-03-2009, 07:33 PM
mbarros
I have a front Air Locker on my jeep as well as an on board air compressor. Do I need to be running the compressor in order to activte the locker?
mbarros is offline
post #36 of 115 Old 09-03-2009, 07:45 PM
1998zj
Yes you do
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #37 of 115 Old 09-03-2009, 08:05 PM
mbarros
thanks...do I need to leave the compressor on or just when I engage the lockers and take them off
mbarros is offline
post #38 of 115 Old 09-03-2009, 08:22 PM
1998zj
If you lose air pressure your locker will disengage.
1998zj is offline
post #39 of 115 Old 09-14-2009, 12:49 AM
Mediarocker
1993 XJ Cherokee
From what I know very little of Air Lockers, You need to Leave the compressor on when engaging and disengaging the lockers. The Compressor needs to stay on when the locker is ON.
The only time i can see a problem here is if you are required to run the axle locked for a long time whereas a Light/Medium duty compressor would not be subject to "Continuous" duty it would wear out and the compressor would fail. The best idea is to get a Tank where the Air compressor can store air, and turn on and off thanks to a pressure switch in the line. When the Air pressure in the tank falls below a predetermined level, the switch turns the compressor on.
Whats also good about this system, is you can use it to air up your tires after wheeling the trails.
When/If I get an airlocker i'm going to put a compressor tank in right off the bat. Do it right the first time
Help JF anyway you can. Click Here.
Threadkillers - Making Posts So Epic, They Destroy Threads
Anything will fit with IMAGINAAAAAAAAAAAATION!........and a Sawzall!!!
Currently Jeepless against my own will.
Mediarocker is offline
post #40 of 115 Old 09-14-2009, 12:14 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
An ARB air compressor does not need to run continuously to keep one or both ARB air lockers locked up, not even close.
So long as the system is not leaking from a faulty installation, you can keep a pair of ARB air lockers locked up all day and the compressor won't usually have to run at all, or perhaps just a short burst towards the end of the day. When I wheel with a particular group of wheelers that mostly all have ARB lockers, I might hear one ARB compressor cycle on and then shut off a few seconds later during the day but that's it.
Getting Savvy...
Jerry Bransford is online now
post #41 of 115 Old 09-14-2009, 01:29 PM
Mediarocker
1993 XJ Cherokee
Thanks for clearing that up Jerry
You have made me sway more to air lockers right now
post #42 of 115 Old 09-14-2009, 01:45 PM Thread Starter
Jerry Bransford
Administrator
If I had the extra $$$ laying around, I'd convert both my my lockers (Detroit Locker and No-Slip) to ARB Air Lockers in a heartbeat. Not that either of my present lockers (both are 8-9+ years old) have ever given me any trouble.
Getting Savvy...
post #43 of 115 Old 09-19-2009, 10:27 AM
cschoeny
Ive got a few more questions. Before you were talking about auto lockers. Does a Detroit locker release the outside wheel when turning? And how does a Loc-Rite locker work?
cschoeny is offline
post #44 of 115 Old 09-23-2009, 06:22 PM Thread Starter
Jerry Bransford
Administrator
A Detroit Locker is an automatic locker which really only means that its normal mode is locked but that it releases the outside wheel when it turns faster than the inside wheel so it can ratchet through the turn. That is exactly how a ratchet wrench works too. Also, the more power applied through the locker, the harder it becomes for that outside wheel to unlock so its best to coast (or at least not apply much power) through turns with any automatic locker.
Getting Savvy...
post #45 of 115 Old 10-01-2009, 07:26 PM
McDowra
YouTube - ARB Air Locker Demonstration is a good locker demo on video.
McDowra is offline
What? Why do I need a locker? I thought I had 4WD! Jerry Bransford Engines & Drivetrain 67 12-29-2015 04:50 AM
How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle. CanukYJ Fabrication Shop 107 12-04-2011 07:14 PM
Stock front locker with Detroit rear locker wiring question RallyeX Engines & Drivetrain 2 06-13-2011 11:45 PM
front locker vs rear locker. ms198 Engines & Drivetrain 7 01-14-2011 01:44 PM
Front locker vs. rear locker airtraffic007 Engines & Drivetrain 16 04-09-2008 11:04 PM
