-   General Jeep & Off-Road Equipment (http://www.jeepforum.com/forum/f27/)
-   -   What? Why do I need a locker? I thought I had 4X4! (http://www.jeepforum.com/forum/f27/what-why-do-i-need-locker-i-thought-i-had-4x4-242949/)
Jerry Bransford 02-24-2006 11:56 PM
Here's something I wrote years ago that was recently revived on another forum... I thought it might be useful here too. :)
Q: Why do we need lockers, I thought I had four wheel drive!!??
A: We need lockers for tough terrain because the differentials installed into our front and rear axles have a characteristic that can turn our 4x4 Jeeps into 4x2 Jeeps in low traction situations.
A factory differential (sometimes called an "open differential") has a characteristic in that when one wheel loses traction, that wheel will start spinning ineffectively. You've seen that happen before, I'm sure. The bigger problem is that one spinning wheel on an axle causes both wheels to lose power to the point you can't move your Jeep... so even though the wheel on the other non-spinning side may have excellent traction, that non-spinning wheel won't receive enough power to keep you moving. Why? Because the differential screws up and only "sends power" to the wheel that is spinning. That is not technically totally accurate but it illustrates the problem very nicely, with a more technically accurate explanation as follows.
So the engine, via the drive shaft and differential, is seeing very little resistance from the axle with the spinning tire. So what? If the engine sees little resistance, it develops little torque. Low resistance to the engine, low developed torque. Lots of resistance to the engine causes it to develop lots of torque. Connect a dynamometer to an engine without a load on it and it'll show very little developed torque. Now put a brake of some kind against the engine output shaft (to add resistance) and the amount of torque developed by the engine will suddenly and dramatically rise. No resistance, very little developed torque... high resistance, a high amount of developed torque.
When a wheel starts spinning, the reduced resistance the engine sees from the axle causes the engine to dramatically reduce the torque the engine develops and sends to the axle. Here's what else is going on that is a key to understanding this whole thing... a stock factory differential ALWAYS ALWAYS ALWAYS splits the torque it receives from the engine 50:50 to each wheel. Exactly 50-50, every time. So when one wheel is spinning and the engine torque decreases dramatically because of that, the OTHER wheel that still has good traction is seeing 50% of the greatly reduced torque. In fact, the torque sent to the axle is reduced so greatly that when the differential divides it 50-50, there is insufficient torque for the wheel with good traction to keep you moving. This means you're stuck!
So when you're driving on a dry paved road, both tires are receiving equal amounts of power and the high traction they're seeing from the dry road helps the engine to develop maximum torque. Both tires are pushing equally with lots of available torque. Now jack up a wheel (or lift it with a rock on a trail you just drove over) and you're not going to move even though the other tire is still on the ground. The tire in the air is spinning like crazy, causing the torque that axle receives from the engine to go right into the toilet.
So, when one tire on the axle is spinning, you don't have enough power for the other tire to keep you moving. For obvious reasons, all this is a huge problem for a 2wd vehicle (just one axle to drive you). It works exactly the same for a 4x4 but you have one more axle to assist in keeping you moving. But if one tire per axle has poor traction, you are stuck... since one spinning tire per axle is enough to reduce all developed torque from the engine down below the point the Jeep needs to move forward.
OK, we know what the problem is now, what's the fix? One, you could STEP ON THE BRAKES a little... which would stop the tire(s) from spinning so more torque would be developed, which should be enough for the OTHER tire that still has good traction to get you moving again. Stepping on the brakes forces the engine to work harder so it develops more torque which is sent to the wheels... so that gets more torque sent to the wheel (both actually) that still has traction so you may be able to get unstuck. Yes, stepping on the brakes (to a point best learned by practice) works rather well in these situations. Just about all drivers used to know that technique when few roads were paved... but it's just about a lost art now.
So what does a locker do? It mechanically LOCKS the left and right wheel together to overcome the above problems. It won't allow one wheel to start spinning while the other sits doing nothing. The left and right wheels are mechanically locked together.
Automatic lockers keep the left and right sides locked together except when you turn left or right, where it will automatically unlock the outside wheel during the turn until after the turn is completed at which time it locks up again. When the locker unlocks for a turn, the outside wheel is allowed to rotate faster than the inside wheel so it doesn't hop and skip during the turn. The inside wheel is driving during a turn with an automatic locker-equipped vehicle. The locker automatically locks again once both wheels are turning at the same RPMs again.
The problem with an automatic locker is that most are not very street friendly when installed in the rear axle. Because they keep the left and right wheels locked together except when forced to unlock for a turn, they can cause unusual handling characteristics like rear-end waggle, tire chirping, disconcerting loud bangs and snaps from the locker, and even sideways sliding down slippery off-camber slopes where they earned the nickname "low-side finder"... which can sometimes produce a high 'pucker-factor' at times. For offroading however, locker's negatives are far outweighed by their benefits in challenging conditions.
But in many Jeeps like the TJ, an automatic locker is fine when installed in the front axle. Since the front axle doesn't receive torque in 2wd, a front automatic locker unlocks easily enough for turns that you may not even notice its presence. Only in 4x4 is the front axle receiving torque which makes it harder for the locker to unlock for turns. About the only conditions where an automatic front locker would not be good in the type of 4x4 system a Wrangler TJ has would be on icy or snow-covered roads where you need 4x4. In 4x4, a front automatic locker would cause understeer (make the Jeep want to drive straight in a turn) which would not be good if the road was slick from snow or ice.
A manual locker is "open" (unlocked) until you actuate it. The ARB Air Locker and the cable-actuated Ox-Locker are examples of manual lockers. These are good because they remain unlocked until you choose to lock them. This eliminates the handling problems automatic lockers have on the streets.
By the way, a locker is installed inside the differential and it replaces the "spider" gears that make a differential work they way it does.
So some Jeepers add lockers in the rear, others add them to the front. I happen to think locking the rear axle first does the most good, but I have installed automatic lockers into both axles which works pretty darned well. But if your rear axle is the notoriously weak Dana 35c that comes stock on all Wranglers except the Rubicon and Unlimited, avoid installing a locker into it and install the locker into the front axle instead. Since the front axle rarely receives more than 50% of the torque that the rear axle does, it can usually handle a locker without problem with reasonably sized tires. But if your rear axle is the optional and far stronger Dana 44, by all means install a locker into it if your trails are tough enough to make a locker desirable.
So what's a limited slip differential? First, it is not the same as a locker. It is more or less an automatic brake for the spinning tire... it performs kind of like when you use the step-on-the-brakes technique so the spinning side gets coupled to the non-spinning side for more resistance so more engine torque can be generated so the non-spinning tire receives more torque from the engine to help get you moving again. It operates as a brake somewhat by coupling the added resistance of the side with more traction/resistance to the side that has less traction/resistance. A LSD depends on some tire spin to get it working so it's not as efficient for challenging terrain as a locker is. But then generally speaking, a LSD is far more "driver friendly" on the streets, which is why we all don't just have lockers in our Jeeps.
Hope this helps a little. :)
JeepCollector 03-04-2006 06:29 PM
Great write-up! The paragraph about the reduced engine torque is the most difficult part to explain to someone. Now just bring your description up to date by adding Brake Traction Control. ;)
jzmtl 03-17-2006 01:27 PM
http://auto.howstuffworks.com/differential.htm
Personally, the torque transfer mumbo jumbo never made much sense in a technical sense to me until I figured out how exactly differential gear works, so above link may be helpful for anyone who's new to this stuff.
Car RamRod 11-08-2006 11:12 AM
Originally Posted by Jerry Bransford
OK, we know what the problem is now, what's the fix? One, you could STEP ON THE BRAKES a little... which would stop the tire(s) from spinning so more torque would be developed, which should be enough for the OTHER tire that still has good traction to get you moving again. Yep, stepping on the brakes (to a point best learned by practice) works rather well in these situations. Just about all drivers used to know that technique when few roads were paved... but it's just about a lost art now.
thats new to me.
Im gonna have to try it.
noodlestsc 11-09-2006 02:25 PM
Originally Posted by Car RamRod
thats new to me.
Yes that has gotten me going a few times. It's obviously no substitution for a LS or full locker but in light situations it usually will help give you that little extra push needed to get going.
XJHERO 11-09-2006 06:12 PM
Very interesting. my question is will manual lockers still unlock in a turn or will you have to manually unlock them and then re-lock them when you straighten back up. I want to put a set of lockers in my XJ but unfortunately its my daily driver so auto locker probably wouldnt be the best bet due to much more street driving than off highway.
ronprice 11-13-2006 06:53 AM
Braking to get going
Remember that with front disc brakes they opperate first. So if in 2wd ,if your back brakes are not adjusted properly your fronts will hold an this will not work. I use my E brake in this sittuation for it only applys to the back brakes. If in 4wd apply a little to both to put power to all 4 wheels not just to front or back
ronprice 11-13-2006 06:58 AM
For normal steet driveing just unlock the hubs to take the lockers out of the stituation. or mke sure front end is unlocked if in newer models with split axle. rearend should be ok with manuals you would leave it unlocked when steet driveing anyways and autos if good ones should work well unless you like to power around corners instead of easing around them and swing a little wide where you can helps to
user jeep 12-04-2006 10:29 AM
when do you step on the brakes? when ur giving the jeep gas, or in between?
jacks90xj 12-07-2006 09:14 AM
Well after reading this post I understand so much more about how exactly the rerend of my XJ works and I learned a trick or two on off-roading. Thanksfor explaining it usig crayons and Mr. Poatoe Head. Really, it helped a ton.
Jerry Bransford 12-14-2006 12:08 AM
When the tires are spinning... which is when you are giving it gas. :)
240M3SRT 01-11-2007 02:27 PM
If this is true then whats the point of a locker? Doesnt a locked diff distribute 50-50 tq every time? And stock diffs usually create a "one wheel wonder" effect from what ive seen at the drag strip. If both wheels were getting 50-50 tq that wouldnt happen would it. Thats why we weld the diffs on some drag cars.
Im just trying to better understand, sorry im more used to racing applications than off road...this is a new game to me.
jneal 01-17-2007 02:20 PM
maybe because the spinning wheel has no tourque. so the non spinning wheel gets 50% of nothing. Does that make sense at all?
molsenice 01-25-2007 05:29 AM
if I'm not mistaken, a locker will lock the axles together when activated - hence the name - the what was previously traction less wheel will still spin, more like rotate, but at the same rate as the tire still in contact with the ground.
great article - I kinda knew what they were and what was going on - this spelled it out.
BradG 02-15-2007 10:21 PM
So I was going to try the step-on-the-brake method yesterday when some sorority girl got her 4x4 KJ stuck halfway in a snowbank, but wasn't sure how to do it and didn't want to mess up her car (that and somebody else had already hooked his truck up to pull her out). So do you pump the brakes or just slowly add them until you start getting traction? :confused:
The time now is 04:40 PM.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
