What? Why do I need a locker? I thought I had 4WD!
#31 | |
Student of Jeep stuff...
Finished Hand Throttle Installation
Here's the Rubicon Exress Hand Throttle (installed) in my 2005 X...
STU OLSON'S d/35 Superior CCE + PowerTrax install d/30 Aussie Install d/30 Superior 27 Spline Evolution Series shafts install d/30 Pinion Seal replacement Spark Plug Tech Keeping the front end "down"/hill climbs/Instant Center... Last edited by RaggedOleMan; 05-13-2010 at 10:35 AM.. |
#32 |
thanks for the awesome post. just bought my wrangler yesterday so the more i learn the better
#33 |
that was a lot of good information for a newbie such as myself. It explained a lot I didn't understand
#34 |
i learnd a lil trick which most of you probly already know but if you dont have lockers like me just hold the brake a lil when you lose traction with one tire this locks up the loose tire and tricks the stock diff
#35 |
I have a front Air Locker on my jeep as well as an on board air compressor. Do I need to be running the compressor in order to activte the locker?
#36 |
Yes you do
"Our lady of blessed acceleration don't fail me now" |
#37 |
thanks...do I need to leave the compressor on or just when I engage the lockers and take them off
#38 |
If you lose air pressure your locker will disengage.
#39 | |
The only time i can see a problem here is if you are required to run the axle locked for a long time whereas a Light/Medium duty compressor would not be subject to "Continuous" duty it would wear out and the compressor would fail. The best idea is to get a Tank where the Air compressor can store air, and turn on and off thanks to a pressure switch in the line. When the Air pressure in the tank falls below a predetermined level, the switch turns the compressor on. Whats also good about this system, is you can use it to air up your tires after wheeling the trails. When/If I get an airlocker i'm going to put a compressor tank in right off the bat. Do it right the first time ![]()
Help JF anyway you can. Click Here. Threadkillers - Making Posts So Epic, They Destroy Threads Anything will fit with IMAGINAAAAAAAAAAAATION!........and a Sawzall!!! Currently Jeepless against my own will. |
#40 | |
Do it right or not at all
![]() Join Date: Jan 2003
So long as the system is not leaking from a faulty installation, you can keep a pair of ARB air lockers locked up all day and the compressor won't usually have to run at all, or perhaps just a short burst towards the end of the day. When I wheel with a particular group of wheelers that mostly all have ARB lockers, I might hear one ARB compressor cycle on and then shut off a few seconds later during the day but that's it.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#41 | |
You have made me sway more to air lockers right now ![]()
#42 |
If I had the extra $$$ laying around, I'd convert both my my lockers (Detroit Locker and No-Slip) to ARB Air Lockers in a heartbeat. Not that either of my present lockers (both are 8-9+ years old) have ever given me any trouble.
#43 |
Ive got a few more questions. Before you were talking about auto lockers. Does a Detroit locker release the outside wheel when turning? And how does a Loc-Rite locker work?
#44 |
A Detroit Locker is an automatic locker which really only means that its normal mode is locked but that it releases the outside wheel when it turns faster than the inside wheel so it can ratchet through the turn. That is exactly how a ratchet wrench works too. Also, the more power applied through the locker, the harder it becomes for that outside wheel to unlock so its best to coast (or at least not apply much power) through turns with any automatic locker.
#45 |
YouTube - ARB Air Locker Demonstration is a good locker demo on video.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
