What is spline count? - JeepForum.com
post #1 of 11 Old 04-10-2003, 11:33 AM Thread Starter
Roughneck
Roughneck's Avatar
Hi, I think I have a pretty good handle on most things mechanical. But I've never been able to figure out why higher splined axles are stronger.
Aren't they just more grooves cut into the axle shaft, and wouldn't that make the grooves smaller and just easier to strip out & spin?
Start with the basics if you don't mind. Splines are the inner end of the axle, correct?
Roughneck is offline
post #2 of 11 Old 04-10-2003, 12:56 PM
Quan
Quan's Avatar
I'll tell you what gator told me. If you look at some of the portal axles on unimogs, they look like they are 4 spline, big cuts into them. So the more cuts you have, the smaller the notches, but the less you have to cut into the axle. So the splines arent as 'tall' and harder to break. make sense? probably not
There comes a time... In every mans life, when decisions... have... to be made. Whether to toil, to labor, or just plain piss your days away.
Green Jeep Club Member #15
My Jeep Made Me Broke Club Member #2
93 YJ I-6 w/ stuff
Keep the greasy side down
Quan is offline
post #3 of 11 Old 04-10-2003, 01:36 PM
01Sport
I have been wondering the same thing. I guess I need a demo in person. Thats beginning to help but no completely. Roughneck, did you get it?
Thanks Quan!
2002 Grand Cherokee Overland. 2" BB. Moab Wheels.
Sold:
2001 TJ Sport :(
01Sport is offline
post #4 of 11 Old 04-10-2003, 05:20 PM Thread Starter
Roughneck
Roughneck's Avatar
This may be something I will have to take on faith. If you make more splines, they have to get smaller and shallower, at some point they will just round off and let the axle spin, right?
Is there some number of splines that you can't go over?
post #5 of 11 Old 04-11-2003, 04:01 PM
RodeoRob
RodeoRob's Avatar
also remember, the more splines you have the more surface contact and you're dividing out forces more.
The number of splines you can have is gonna correlate to shaft diameter as well. You can build a Ford 9" to have 40-spline shafts, thats about the highest count i'm aware of.
-Rob
RodeoRob is offline
post #6 of 11 Old 04-11-2003, 10:36 PM
Quan
Quan's Avatar
i think theres a company making 43 or 35 spline..but not sure
93 YJ I-6 w/ stuff
Quan is offline
post #7 of 11 Old 04-11-2003, 10:56 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
RodeoRob hit it on the head - it's all about more surface contact - the same thing is true about bolts - the fine threads can handle significantly more torque than a bolt of the same size & grade in a coarse thread.
Steve
OldJeepguy is offline
post #8 of 11 Old 04-18-2003, 02:24 PM
Mels95YJ
Mels95YJ's Avatar
I never knew that! I guess you can teach old dogs new tricks.
Mel
Jeep with stuff.
Mels95YJ is offline
post #9 of 11 Old 04-19-2003, 03:43 AM
I-4
I-4's Avatar
-Rob
40 is the most splines you can get for any axle at this point.we all know how fast that changes. what rob said + the more splines you have, the bigger the shaft has to be to accomodate all of those splines.
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #10 of 11 Old 04-19-2003, 03:45 AM
I-4
I-4's Avatar
i don't have spiders in my rearend...
i got rid if those when i did my axle swap. spools rule!
95 yj...
I-4 is offline
post #11 of 11 Old 04-22-2003, 08:10 AM
01Sport
OK, can someone tell me the difference between spider gears and spools.
Sold:
2001 TJ Sport :(
01Sport is offline
axle spline count muxi0121 Engines & Drivetrain 1 04-29-2008 04:16 PM
Spline Count Help ONX Engines & Drivetrain 3 05-01-2007 10:09 AM
spline count help Sundvl-88YJ Engines & Drivetrain 2 10-18-2006 01:17 AM
Spline count on the D44 yoke jeepin494 General Jeep & Off-Road Equipment 7 08-02-2005 09:59 AM
Spline Count Anoyher General Jeep & Off-Road Equipment 4 10-22-2003 05:22 PM
