What size winch should I put on my Wrangler? - JeepForum.com
post #1 of 24 Old 05-15-2009, 02:29 AM Thread Starter
06CatM7
I purchased my first jeep ('93 Wrangler) this winter and I would like to add a winch. What size winch should I look at?
Thanks for the information!
06CatM7 is offline
post #2 of 24 Old 05-15-2009, 07:42 AM
wes19d
Anything from 8 to 10 thousand pounds should be just fine.
05 RUBI
wes19d is offline
post #3 of 24 Old 05-15-2009, 12:04 PM
Terrible2
I think the rule is 1.5x the weight of your vehicle. or possibly 2.5x. either way you go the more pulling power it has, the longer it will most likely last since it'll do alot less work.
Terrible2 is offline
post #4 of 24 Old 05-15-2009, 03:07 PM Thread Starter
06CatM7
Thanks guy!
It looks like I'm looking for at least a 8K winch (2.5x of vehicle weight). Any other brand besides Warn I should look at to purchase?
06CatM7 is offline
post #5 of 24 Old 05-15-2009, 03:15 PM
Terrible2
Milemarker and smittybilt have them for cheap. Id only use them if you plan on using hte winch once or twice a year as theyre not as reliable as warns in my opinion. I'd go with a Warn for quality though, theyre amazing.
post #6 of 24 Old 05-15-2009, 03:36 PM Thread Starter
06CatM7
Well, it looks like a Warn it will have to be....I'll probably get stuck 2-3 times a trip!
06CatM7 is offline
post #7 of 24 Old 05-15-2009, 07:04 PM
RogueSpear2023
Also look at superwinch the make some nice winches too, very comparable to Warn, I am partial to Warn though, I have there ATV winches and love them. Warn has great customer service too.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #8 of 24 Old 05-18-2009, 04:36 PM
lifted1992yj
warn and ramsey are top of the line. and you defiantly get what you pay for. superwinch and milemarker are good quality for the price. also don't forget about a snatch block. they can double ur line load if needed.
lifted1992yj is offline
post #9 of 24 Old 05-18-2009, 05:28 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
One thing not many realize is that the bigger the winch capacity, the less amperes the winch will require from the Jeep's electrical system at the same load. For example, a 9,000 lb. capacity Warn XD9000 winch requires 135 fewer amperes from the battery to retrieve a 6,000 lb. load than a Warn M6000 6,000 lb. capacity winch does when retrieving the same 6,000 lb. load.
For example: when pulling 6,000 lbs, the Warn M6000 requires 465 amps while the Warn XD9000 only requires 330 amps to pull the same load.
So when choosing winches, it is generally better to go to a slightly heavier capacity winch whenever possible.
Getting
Jerry Bransford is online now
post #10 of 24 Old 05-18-2009, 08:56 PM
1996BlackXJ
Never thought of it that way, very insightful!
Thanks
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #11 of 24 Old 05-19-2009, 07:59 AM
Ross
Another thing to think about is the bigger you build you jeep, the worse it will stuck. I have a Warn 9500 on my jeep and it has always pulled me out with out a problem. Sunday I pulled out a tractor stuck in mud. It dragged my jeep forward about 3 feet before we got it out. I had the cable on a pulley and rigged striaght back to the jeep and I barely got it out. It was stuck in the mud to the axle and had a plow barried under the mud. The tractor weighed less than the jeep. The hardest pull ever was a stuck Suzuki Samari. I guess my point is do not rely the 1.5X the weight formula, even though a vehicle is light it can get very stuck increasing the amount you need to pull.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #12 of 24 Old 05-19-2009, 10:29 AM
Hampster
x2...I never thought of it this way either^^
01' WJ Limited - Quadradrive, V8, Daily Driver, 149k
Hampster is offline
post #13 of 24 Old 06-09-2009, 07:17 PM
default_user2
Have you ever used a milemarker? I've been doing some research on them and it seems the MM electrics are pretty much junk but there hydraulic winches are very dependable except that the line speed is a little slower...
default_user2 is offline
post #14 of 24 Old 06-09-2009, 08:32 PM
NE4X4
Jerry makes a good point on the advantage of larger winches using less amps. In addition to that, it is possible and even likely that you will use your winch for more than just tugging yourself out. I have pulled more full size pickups than I ever have pulled myself. I only have a 8000 lb. winch and I sure wish I had a larger one sometimes. So if funds allow, get the largest winch that is practical.
NE4X4 is offline
post #15 of 24 Old 06-09-2009, 09:47 PM
default_user2
It's kind of the equivalent of slapping a V-8 in a Wrangler. Although it's a bigger motor and has two more cylinders, the V-8 doesn't have to work as hard as the I6 so they don't suck as much gas.
Obviously this is talking about a mild modern day V-8. a 454 out of a 70's truck isn't going to improve your mileage
What size winch is best?? Dan's YJ General Jeep & Off-Road Equipment 33 01-08-2011 08:28 AM
winch size boone78 General Jeep & Off-Road Equipment 6 04-06-2009 03:29 PM
Size Winch Brindle19 General Jeep & Off-Road Equipment 7 10-12-2005 04:34 PM
What winch size? fastfive0 General Jeep & Off-Road Equipment 17 08-13-2003 07:42 PM
Winch size? rsmnc General Jeep & Off-Road Equipment 9 10-11-2001 08:06 PM
