What are the *must have* winch accessories?
| RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road |
#1 | |
My TJ came with a winch that the 1st owner installed. Just has the steel cable with a hook on the end (well, roller leads too).
What's some *must have* winch accessories that one should keep in the Jeep in case I ever need to use it for pulling either myself or someone else's vehicle out of a ditch? I know you're not suppose to wrap the steel cable back upon itself or you'll kink it, so I picked up one of those 20ft seatbeat-looking tow straps, I figure I can use that to wrap around a tree if I need to use that as an anchor point for pulling my jeep out. What else should I invest in? Also, if you're say pulling someone's car from a snow bank, what's the best way to attach to their vehicle? Thanks, I'm a winch noob!
#2 | |
Straight Up Fool!
snatch block
tree saver strap quality recovery strap gloves screw shackle(s) 10,000lb+ rated tow chain (short) It will save you money to buy a winch accessory kit that has everything rather than buying individually. Warn sells one, as do probably most winch manufacturers. When I pull someone else's vehicle I always let them hook to it. The I check that I don't feel it is unsafe before pulling. Then they are responsible for their own vehicle damage.
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#3 | |
no whiners!
#4 |
seen a snatch block used not a fan personaly but you never know when you need it
99 TJ 4.0l 5speed, 4 inch suspension 3 inch body, 35 bfg km2 tires |
#5 | |
More Money than Brains
#6 |
snatch blocks will double the winch's pulling capacity. when used with a tree strap, they also allow changing the winch line direction. this is key in some circumstances.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#7 | |
Straight Up Fool!
It can also be handy to cut the pull speed in half sometimes!
#8 | |
Straight Up Fool!
On my to do list for sure!
#9 |
true! i've heard some of the guys with Warn 8724's complain they move too fast!
#10 | |
Straight Up Fool!
I'm just a chicken when I'm using my winch. If I'm winching up anything the least bit technical I prefer to do it as slow as possible!
#11 |
Demonic Jeep Freak!
A big tree or rock.
#12 | |
If you are planning to keep the steel cable (even temporarily) get a weight bag for line weight. Fill it with sand and suspend it from just forward of the middle of the steel line. I saw a steel line break once and nearly remove a guy's leg. It was a bloody disgusting and un-necesary mess. Once you have the equipment, take the time to learn to safely use it. IMHO - I'd plan on getting synthetic as soon as possible. |
#13 |
Eat. Sleep. Jeep.
ARB has another, which I like better than the Warn. Of course, you really can't beat the quality of the stuff in the Viking kit! They do use ARB snatch blocks, and their own line.
My Build 2005 TJ Sport, Light Khaki Metallic RE 3.5" coils, OME shocks, Currie control arms, JKS track bars, JKS 1.25” BL, JKS 1” BMML, 35x12.5x15 Goodyear MT/Rs, American Racing ATX Chamber (Teflon), JB Conversions SS SYE, Tom Woods driveshaft, Savvy Gas Tank Skid, Warn 9.5ti, Viking synthetic winchline w/safety thimble, Metalcloak bumper, Metalcloak steering box skid, Savvy rear bumper, HP30 w/Aussie Locker, Barnett cover, XRF ball joints, Savvy tie rod flip, mini-skids, housing end JJ's, , Currie Steering, OME steering stabiliser, Metalcloak Tube Fenders/rear flares/rocker guards, ORO SwayLOC, Banks Stinger Exhaust, Cobra 75 WX ST with Wilson Silver Load, S-POD, Alpine/MOPAR RB1 Navigation Unit w/MOPAR iPod integration, Superlift Truspeed speedo correction, Lightforce 140 Lance driving lights, OTRATTW switch panel, Tinted UPOL Raptor Liner, Savvy Black Magic brakes, Centric rotors, Superior Evo rear shafts In the garage: Viking Offroad 350 series Hawse fairlead, ARB compressor, Savvy corner guards, Novak 231 cable shifter, EBC green stuff/Centric rotors (rear), Savvy tub rails, Savvy taillights |
#14 |
Not to sound like a jerk but make sure you have the winch control and test it before you need it. Check the line to make sure it isn't damaged and the cables aren't frayed or going to short. I run a 150amp breaker on mine to be safe.
I have a Viking line and love it! It is so much easier to pull and handle than a steel cable. They aren't cheap but my 9yr old son can pull it and handle it SAFELY. I don't have to worry about it whipping back on him as he pulls it. So it is cheaper than stitches and easier than explaining it to his mom
[QUOTE=mrblaine;8400660]I'm a huge fan of body lifts. In fact were I in your shoes, I would have gone for the 4" body lift and some 2" spacers on stock springs.[/QUOTE] |
#15 |
Running Secretly Amok!
Have used a snatch block twice on Miller Jeep trail. Being able to change the direction to 90* was money well spent.Wouldn't be without!You never know!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
