What glue is good for metal to plastic?? - JeepForum.com
post #1 of 3 Old 04-14-2013, 09:40 PM Thread Starter
YellowJeepGuy94
My Bushwacker TrailArmor Rocker Panels are starting to fall off. What glue should I use for it? Super glue did not work. Thanks
YellowJeepGuy94 is offline
post #2 of 3 Old 04-14-2013, 10:13 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I take it these get knackered about quite a bit?
Most adhesives won't give you good structural strength on a join like that. If I really wanted it to stay put, I'd use rivets, coating the shanks with RTV (which will help keep the drilled panel from rusting around the rivet holes.)
Epoxy is a possible, but it isn't very flexible, and will generally fracture under stress when used as an adhesive bond (in my experience.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #3 of 3 Old 04-16-2013, 02:25 AM
Icarus
Goop
You'll need to hold them on till it dries though...
Ϣr
Icarus is offline
