What do i air down to? - JeepForum.com
post #1 of 11 Old 06-19-2014, 09:44 AM Thread Starter
Kdailey13
2011 JK Wrangler
I recently put 35x12.5 mt/r kevlars on my 17x9 rims and i was wondering what psi i should air down to without worrying about added risk of disturbing the bead or the tire on the rim.
Kdailey13 is offline
post #2 of 11 Old 06-19-2014, 09:54 AM
wilson1010
Tires do not debead above 15psi unless you are in an accident. Between 6psi and 15 psi they can debead given the proper conditions. With the wheels straight ahead, i have never debeaded a tire above 8psi. With the wheeels turned and pushing our local clay downhill, I can intentionally debead any tire at 8psi or below. It only takes about 300 pounds of resistance from the ground to pull the bead off at 8psi.
You double your contact patch going from 32 to 16. Four time going from 32 to 8.
Learn how to re-bead a tire if you are going to go below 12-15. Expect to re-bead a tire if you go below 6. It is not as easy as it looks when you are at the bottom of a hill with your rig at a 20 degree downward angle, stuck, and the rim has 10 pounds of clay in it.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 11 Old 06-19-2014, 09:55 AM
222Doc
222Doc's Avatar
well on my 15x8s with 35x12.5 normal air down is 10psi and i can push it as low as 7/8. though i have had a bead slip at 7. I think from 10-12 you should be ok anything over 12 is about like not airing down anyway. I run 27 on the road. I mean anything can happen it the way it is.
222Doc is online now
post #4 of 11 Old 06-19-2014, 10:08 AM Thread Starter
Kdailey13
2011 JK Wrangler
Cool thanks a lot guys!
post #5 of 11 Old 06-19-2014, 10:30 AM
olliehopnoodle
1982 FSJ Cherokee
I typically go down to about 13. Never lost a bead. BFG 35's on 15" rims. Arizona wheel'n. Really helps on the wash board roads. I get decent bite driving over rocks. Start around that and see if it works for you.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #6 of 11 Old 06-19-2014, 10:58 AM
Ross
I had 10" rims and could lose air around 10 psi, I now have 8 inch rims and haven't lost air at that level. I have 15 inch rims (diameter), not sure if that would make a difference or not.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #7 of 11 Old 06-20-2014, 10:09 AM Thread Starter
Kdailey13
2011 JK Wrangler
Cool ill probably try 15-16 and work my way down
post #8 of 11 Old 06-22-2014, 07:14 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
We run a lot of sand and for shoving a recovery rig out there, we run 15-18 LBS with no issues. My biggest dislike is takng the time to air back up. An F350 running 50 LBS of air in the tires can take some time to get back to highway pressures, a must if your sand camping and hauling a trailer.
jeepdaddy2000 is offline
post #9 of 11 Old 06-22-2014, 08:20 AM
JIMBOX
I rarely air-down, sand/rocks-
If I have to in snow, my STAUNS are set to 18psi--nuff
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #10 of 11 Old 06-22-2014, 11:04 AM
strvger01
1966 CJ5
i had all my tires tubed. would run all weekend at 5-8psi. just aired them back up for the sunday trip back home. one thing that might have helped as well were that they were 235/85x16 E-rated tires with stiffer sidewalls. but the ride both on the trail and the road were good. just need to calculate for the correct psi for the dd ride comfort.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #11 of 11 Old 06-22-2014, 12:42 PM Thread Starter
Kdailey13
2011 JK Wrangler
Awesome thanks guys!
