"We couldn't do the alignment because... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > "We couldn't do the alignment because...
Unread 07-03-2013, 08:20 AM   #1
Agony Wagon
Antiseizeaholic
Agony Wagon's Avatar
1995 XJ Cherokee
...whoever put the lift kit on put longer lower control arms, but didn't put longer upper control arms."
It's lifted about 3", with 16" fixed LCAs.
Agony Wagon is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 08:24 AM   #2
olliehopnoodle
1982 FSJ Cherokee
You could take it to another shop and/or do some measurements. It wouldn't be the first time someone cut corners on a lift.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 09:10 AM   #3
Imped
Imped's Avatar
So slightly longer lowers and stock uppers? Then they can't adjust caster or the fore-aft axle positioning. They can adjust toe....and so can you. So there's no point to drop any cash on someone doing that for you.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 10:37 AM   #4
Agony Wagon
Antiseizeaholic
1995 XJ Cherokee
I put the lift on. The kit didn't come with different UCAs because there's no major need to adjust them at this lift height. The longer LCAs should keep caster pretty close to where it was before the lift.
I know they could. They said they couldn't. And I've done it before, but I figured they'd be able to get it done more accurately than I could with my crude instruments, being that alignments is one of the more common things this shop does.
The one guy who works there drives a lifted yota. Maybe I should have known better than to take my SFA there?
Unread 07-03-2013, 01:07 PM   #5
olliehopnoodle
1982 FSJ Cherokee
Yeah, take it to a different shop.
Unread 07-06-2013, 10:58 PM   #6
Motorcharge
Bandeded
Motorcharge's Avatar
1991 MJ Comanche
Take it to a shop with older equipment. A lot of bigger shops have the same Hunter alignment machines and a lot of younger technicians don't know how to do an alignment off one so if it shows off on the machine and the specs is says it should be then they don't know how to align it.
| Project Motörcharge 2.0 - MJ | June 2015 COTM |
Motorcharge is offline   Reply With Quote Quick reply to this message
alignment , caster , control arms , lca
