Warn ZEON s10 (Wiring Questions) - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Warn ZEON s10 (Wiring Questions)
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread Yesterday, 11:00 AM   #1
myrddin
2009 JK Wrangler
Hi folks, I asked some of these questions a while back, but in the wrong area... Can you folks tell me what you think is right for what I am doing.
1. should I have a quick disconnect at the pinch for power (I currently do).
2. Should I add the Warn power interrupt kit and control it from my switch pod (thinking about doing this now).
3. Or should I be doing something else...
I have a switch on my switch pod for powering up the winch, and I have already installed the disconnect for the power wire...
I have almost ordered the interrupt kit twice today... but then I second guess my plan...
thanks for your thoughts...
2009 JKU with a Rugged Ridge Short Winch Bumper and a WARN ZEON 10-S winch
myrddin is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:08 PM   #2
14Sport
2014 JK Wrangler
Well it looks like the power wire runs through the grill so you do need the disconnect to remove the grille, if I am looking at it right.
As far as the power interrupt, I have one since I heard some kids spooled out some guys winch, threw it over the roof, attached it to the rear bumper, and then did something ugly. And I wired it to switched power.
However, I live in FL and am not into mud so I haven't field tested it yet doing a recovery. I have only wheeled twice in WV (on vacay) and didn't need it either time. I did test it after install and all was good.
2014JK,auto,MC GCL 2.5",35x12.5x17, 4.56s.
My observations are based on my experiences...YMMV.
14Sport is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:52 PM   #3
1222
Make mine a Jeep!
1222's Avatar
Moved from JK tech.
Dash mount for 2011-2015 JKs
1222 is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 02:26 PM   #4
PhatBasturd
WWRD
PhatBasturd's Avatar
1976 CJ7
I have a switch on my switch pod for powering up the winch...
How did you wire the switch pod to power up the winch?
PhatBasturd is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:10 PM   #5
myrddin
2009 JK Wrangler
I have a daystar switch pod (see pic above)... Basically I need the warn interrupt solenoid to turn on power... If you look at that kit, just think of me using my winch switch instead of the one they supply.
I'm still thinking it over but it sounds smart??
