Warn winch problem. - JeepForum.com
post #1 of 5 Old 05-16-2011, 06:28 AM Thread Starter
adz4play
Warn winch problem.
Hey guys ive searched the forum but only really found winch rebuild writeups, Not sure i need this????
Warn 9000 winch, the clutch lever wont go into its engage position, Its very tight and forcing it feels like the wrong thing to do, I can see how to pop it of but before i do this is there something else i should be doing???? cheers, adz
adz4play is offline
post #2 of 5 Old 05-16-2011, 08:29 AM
TJWAY1
I had the same problem with my Warn Tabor 9K. The gear housing was packed with dirt (and original grease). I had to disassemble the gears, get a new handle from Warn (old one snapped off when I tryed to force it to engage).
I used online instructions for rebuilding a warn m8000 winch. (schematic drawing of your winch is available from Warn)
Cross reference the diagram of your specific winch and the online instructions.
Don' forget to order gaskets (several for thickness) for reassemnbling the gear housing after you clean it up and repack grease
TJWAY1 is offline
post #3 of 5 Old 05-16-2011, 08:55 AM Thread Starter
adz4play
cheers dude, dry evening ill have a closer look....grrrr
adz4play is offline
post #4 of 5 Old 05-17-2011, 03:46 PM
Warn Industries
Vendor
Warn Industries's Avatar
Don't hesitate to call our Customer Service team; they'll help you out.
1-800-543-9276
- Andy
GO PREPARED
Like us on
Follow us on
See us on
Warn Industries is offline
post #5 of 5 Old 05-18-2011, 06:21 AM Thread Starter
adz4play
Thats awsome guys thankyou..
adz4play is offline
Warn Winch Guard Hoop That Bolts to Winch Plate? msully TJ Wrangler Technical Forum 13 04-16-2011 03:42 AM
warn 8274 winch / looking for winch rope jeremy91yj YJ Wrangler Technical Forum 5 06-14-2009 08:36 PM
Warn winch plate fitting winch other then Warn jeepxguy_02 TJ Wrangler Technical Forum 9 11-17-2008 08:44 PM
Warn front bumper, Warn mounting plate and milemarker winch....will this work? Sparty TJ Wrangler Technical Forum 1 01-11-2006 01:13 PM
Warn x8000i on Warn Winch Plate linux24 TJ Wrangler Technical Forum 7 04-07-2005 12:32 PM
