Warn Winch Help... - JeepForum.com
post #1 of 9 Old 02-28-2013, 10:50 PM Thread Starter
frenchy206
Warn Winch Help...
So, I finally got the time to install my Warn M8000. It worked a year or so ago, but sat outside on my friends xj since then. He just gave it back to me and now it doesn't work so well.
When I try to reel the cable in or out, all I hear is click and buzz from the solonoids. The motor doesn't move. I looked at the solonoids, and there is no corrosion.
First, any ideas? What could be wrong?
Second, where is the best place to order replacement parts for Warn winches?
03 TJ Rubicon
frenchy206 is offline
post #2 of 9 Old 03-01-2013, 08:30 AM
Shark_13
How are the battery connections? Solid & tight?
Shark_13 is offline
post #3 of 9 Old 03-01-2013, 08:57 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, check/clean/tighten your winch's electrical connections at the battery (make sure both connections attach directly to the battery). Then if that doesn't fix it, one of the solenoid connections might be loose.
Getting
Jerry Bransford is offline
post #4 of 9 Old 03-01-2013, 12:08 PM
tntempest
The M8000 has another small ground wire for the solenoid pack, make sure it's connected and clean.
2004 Wrangler Rubicon
tntempest is offline
post #5 of 9 Old 03-03-2013, 08:02 PM
elmoe
The brushes/armature for the motor may be rusted. I took mine apart a few years ago and was able to clean them and the armature up. Getting the brushes back together was tricky, but if I can do it anyone can.
elmoe is offline
post #6 of 9 Old 03-03-2013, 08:49 PM
TJDaveX
Sounds like your friend has a Warn winch to repair...if he is a true friend.
I would not even think about returning an item I borrowed from a friend in worse condition than I got it. But, that's a whole other topic.
Warn is the best place to buy replacement parts. Their customer service is great.
TJDaveX is offline
post #7 of 9 Old 03-03-2013, 10:00 PM
dcope17
Warn is the best place to buy used parts. Their customer service is great.
Amen.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #8 of 9 Old 03-04-2013, 04:22 PM Thread Starter
frenchy206
I hear ya. I really can't hold him too responsible as I sold him the rig that had the winch on it. He was supposed to bring me the winch when he had a chance to take it off, as the winch was not part of the deal. As I had no need for the winch, I told him to take his time. Unfortunately, having it sit outside, unused for over a year, caused the issue. He offered to take a look at it, so eventually, it will, hopefully, be working again.
It has to be one of the solenoids.
03 TJ Rubicon
post #9 of 9 Old 03-05-2013, 03:31 PM
Warn Industries
Vendor
Warn Industries's Avatar
Don't hesitate to call our Customer Service at 800-543-9276 if you need help troubleshooting.
- Andy
GO PREPARED
Like us on
Follow us on
See us on
Warn Industries is offline
