Warn winch fairlead - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Warn winch fairlead
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 11-27-2013, 09:49 PM   #1
JFM626
Warn winch fairlead
Earlier this year I needed to use my winch for self recovery. The nearest line attachment point was off to the side a bit, but I got out without much struggle. There was however a bit of collateral damage. It seems that the winch line dug into the vertical roller on the passenger side. Both vertical rollers would not turn by hand, but the horizontal ones were fine.
Finally got around to taking it apart today and found that both the vertical shafts were quite caked with rust. All cleaned up now and ready to reassemble. I am convinced that the rust is caused by water getting by the snap ring at the top and running down the shaft. I really would like to seal the shaft, but short of that I will just put some water proof grease on the shafts.
Any other better/different solutions come to mind?
JFM626 is offline   Reply With Quote Quick reply to this message
Unread 11-28-2013, 09:13 AM   #2
1222
Make mine a Jeep!
1222's Avatar
Seems like a reasonable solution to me. I would also make sure the rollers are free of any burs too and if they are grooved or damaged replace them.
1222 is offline   Reply With Quote Quick reply to this message
Unread 11-28-2013, 09:25 AM   #3
Mean Max
Don't poke the bear
Mean Max's Avatar
Synthetic winch line & hawse fairlead?
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote Quick reply to this message
Unread 11-30-2013, 05:30 PM   #4
Eckoh
you know when i was researching hawse fairleads a guy made an intersting comment. Would you use a snatch block that did not roll??? that is the same using a hawse fairlead on an off angle pull.
Eckoh is offline   Reply With Quote Quick reply to this message
Unread 11-30-2013, 06:44 PM   #5
JFM626
There was enough room under the snap ring to install an "O" ring. I note now that the pin and the roller now turn though, probably because of all the grease I put on the shaft. I'll see what happens under a side load sometime I suppose
