Warn M8000 Problem: Will not Spool In - JeepForum.com
post #1 of 9 Old 07-12-2010, 10:05 AM Thread Starter
Orca
Hi. I got a problem on my M 8ooo. I only can feed the Cable and not pull it in.
So the winch worked properly until now. The winch is not full of Mud or anything else. I can also hear no Click from the solenoids when i try to pull the cable in. I have teste the controller. It is working fine. The motor should be OK,
because hes turning in one direction. I think the solenoids are working also.
There is a little circuit board in the control box. Does anybody had problems with this board? Any help would be fine.
Gretting from Germany
Wrangler,4.0L, Red, MY 01, TerraFlex 3,5" Lift, 265/75/16 Cooper Discoverer STT.
XJ 4.0L Limited,Patriot Blue,00,RE 2" Lift,235/70/16, Goodyear AT/R .Sold !
Orca is offline
post #2 of 9 Old 07-12-2010, 11:45 AM
dcorn
Your winch in solenoid could be bad. I don't have much experience with winches.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 9 Old 07-12-2010, 03:20 PM
KMD
1976 CJ7
Plus 1 on solenoid. Call Warn they will take care of you and help you diagnose it.
KMD is offline
post #4 of 9 Old 07-12-2010, 04:25 PM
zillla
1930 VJ
There are two solonoids.. One is bad.. Replace both..
zillla is offline
post #5 of 9 Old 07-13-2010, 01:11 AM Thread Starter
Orca
Thank for the quwick answers.
I think the problem is the circuit board. Because there is no power at the two solenoids ,for to feed the cable.
And this little circuit board switches the power between cable in and out. Right ? We have only one general Warn Dealer in Germany. so it is not easy, and cheap to get Help from them.
I try to get some help from Warn USA. But if anybody has another idea, any help is apreciated.
Orca is offline
post #6 of 9 Old 07-13-2010, 01:57 PM
BYuen
BYuen's Avatar
Sounds like you've got it narrowed down. If the solenoids aren't receiving any power, then the problem must lie a little further up the line of components. I would give Warn a call and see what they say about the issue. I'm sure they can help you figure out what's wrong. We had a M12000 on my Dad's truck and it would only spool out. It was something wrong with the motor. Everything else was fine and Warn ended up replacing the motor for us free.
BYuen is offline
post #7 of 9 Old 07-18-2010, 12:02 AM
smartshot
you might have the power correctly touching or fastened in. Maybe just as simple as a lose cable.
smartshot is offline
post #8 of 9 Old 07-18-2010, 08:05 AM
imfrompa
Check that you have a good ground... it is always important.
imfrompa is offline
post #9 of 9 Old 07-18-2010, 08:12 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There are four solenoids, two for 'in' and two for 'out'. I would begin by disconnecting the battery's negative cable and then insuring all the cables and wiring connections are tight where they connect to the solenoid. If all connections are tight, odds are that one of the two 'in' solenoids is bad.
You can get an inexpensive replacement solenoid from http://www.db-starter-alternator.com...golf-cart.aspx
Jerry Bransford is online now
m8000 , motor , problem , solenoid , warn , winch
Warn M8000 bmxrules39 General Jeep & Off-Road Equipment 10 03-31-2009 04:56 PM
Warn 9.5XP vs M8000 Shrek General Jeep & Off-Road Equipment 2 11-30-2007 04:22 PM
Warn M8000 or Warn 9500ti? WILLY348 General Jeep & Off-Road Equipment 2 04-23-2007 12:23 AM
Warn M8000 jayr General Jeep & Off-Road Equipment 3 04-12-2007 01:41 PM
Warn M8000 bsruther General Jeep & Off-Road Equipment 32 11-13-2006 08:37 AM
