Uses for 3/8 or 5/16 chain - JeepForum.com
post #1 of 4 Old 05-21-2011, 10:27 PM Thread Starter
freedommachine
2016 JK Wrangler
I carry about 20 feet of 3/8 chain in my jeep for my hi-lift to be used as a winch. Yes I have a winch and know a hi lift is not a great winching tool, but me and my wife prefer to have it. My question is what are some other uses for chains that I have not thought of ??? I Just lack ideas on what else they might be good for. I know not to use them as a tree saver or snatch strap,I seem to know more donts with chains then dos
In memory of JF member: mrknowitall666
Rest in peace brother- wounded warrior find your peace
freedommachine is offline
post #2 of 4 Old 05-22-2011, 12:46 AM
logdog93
As an anchor when winching other objects, around a rock or other object so u don't move
logdog93 is offline
post #3 of 4 Old 05-22-2011, 05:29 AM
RogueSpear2023
I use them for pulling rocks and trees out. No jerking but gentle pulling where a strap would get damaged, I frequently use chains for pulling tree out of the way on my property or dragging the to a place where I can chop them up. I have also used them to pull rocks out of the ground. I have also used it a few times to remove the lawn mower when stuck in the mud, but again no jerking just gently pulling it out.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 4 Old 05-22-2011, 09:04 AM
ZeroGravity
I was just going to say that. A chain will hold tension if you wrap it around an object two or three times and then hook it to itself where as a strap would fall loose and get torn up. Not a lot of uses for straps on a farm so we've always used a big chain for the tractors and to pull fence posts, rocks and trees out of the ground.
I think chain is a good idea for a hi-lift winch because even straps that are not flexible still give a little and you need everything you can get when you're hi lift winching (because you're probably SOL otherwise).
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
Hi Lift winch chain? Notch516 General Jeep & Off-Road Equipment 1 02-22-2011 12:18 AM
amc timing chain cover cmhuslig Engines & Drivetrain 0 12-19-2010 01:21 PM
NP 231 chain slop drivermod Engines & Drivetrain 0 05-02-2009 03:40 PM
231 how much chain stretch Russell_Goodall Engines & Drivetrain 0 03-25-2009 08:20 PM
Which chain for recovery? cnskate General Jeep & Off-Road Equipment 16 04-04-2008 02:37 PM
