used winch okay? - JeepForum.com
post #1 of 6 Old 08-14-2011, 01:13 PM Thread Starter
hrt4me
used winch okay?
Would it be okay to buy a used winch, or do you recommend against it?
If it would be okay to buy a used winch under the proper set of circumstances, then would criteria do you suggest when evaluating whether or not to buy a particular used winch (i.e. things to look for and/or avoid)?
hrt4me is offline
post #2 of 6 Old 08-14-2011, 01:16 PM
TSEJEEPERS
Nothing wrong with buying a used winch.
You can get a heck of a deal on some.
I would make sure you can buy parts for it though.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 6 Old 08-14-2011, 01:26 PM
wolfcreek
I looked at used winches, but between unrealistic seller expectations vs. the discounts and rebates available on new winches, and the lifetime warranty that Warn grants to the original purchaser, I ended up getting a new one.
If I was buying used I would look for a high end winch and look into learning to rebuild/refinish it.
wolfcreek is offline
post #4 of 6 Old 08-14-2011, 01:51 PM
bullchuck
when i prchased my used warn 9000i, i looked at three things;
#1 dose it have power in and out?
#2 dose the lever ingauge and disengauge easy or hard ?
#3 overall looks
If somebody wants to sell it bad enough they will show you that it runs. if they donot then buyer beware.
If the lever turns with out to much force , you should be good to go.IFyou have to use to much force or it dose not move at all , it needs some work inside.
If it is all rusted and beat up it might not be worth the time and money to fix up.
I am shure there are other things to look for , but this helped me to get a good used winch.
Thanks Mark
" jeeps are like women, they are all good, some are just better than others"
bullchuck is offline
post #5 of 6 Old 08-14-2011, 03:16 PM
hammerz71
I bought my M8000 new, bought my 9000i used, but I knew the original owner, knew the winch was only on his truck less than two years and that he'd only used it once. That, coupled with the fact that he was willing to trade it for basically $300 in ammunition was a clincher for me.
My old man bought a used M8274 when I was in junior high (early '80s) and he's still got it, had to rebuild it maybe 8 years ago, but it's been on four different trucks he's had and still works.
I'd probably not mess with a used chinese winch, unless someone was gonna 100 dollar it and it looked to be in real good shape...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #6 of 6 Old 08-14-2011, 04:07 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'd buy a used Warn or Ramsey but I wouldn't touch a used Smittybilt, Harbor Freight Tools, or other Chinese winch. I'd only test it first by connecting it to a battery and seeing if it works.
If it doesn't work but it clicks, odds are it just has a bad solenoid which is very easily replaced with an aftermarket solenoid. A non-working winch is often a huge bargain since few people know enough about them to be able to fix what is usually an easy problem.
Getting
Jerry Bransford is online now
Convert a standard Warn XD9000i Winch into a 'Multi-Mount' front/rear easy swap winch awalp General Jeep & Off-Road Equipment 14 03-31-2011 10:12 AM
Viper Elite Winch Install w/ A to Z winch plate gtstricky General Jeep & Off-Road Equipment 13 05-27-2010 03:30 PM
Rugged Ridge 8500lbs winch or Smittybily 8000lb winch HighRoller02TJ General Jeep & Off-Road Equipment 5 05-20-2010 01:45 PM
Which winch plate is flat to frame and will hold my winch close to grill? CB3 General Jeep & Off-Road Equipment 5 02-23-2010 09:23 PM
brush guard, winch, winch mount compatibility Longspoon General Jeep & Off-Road Equipment 6 07-25-2007 01:48 PM
