tying knots in recovery straps - Page 2 - JeepForum.com
post #16 of 29 Old 11-05-2006, 06:45 PM
sailgclass
1986 FSJ Wagoneer
I'm a sailor, and a scout, and somewhat of a knot geek. Anyway, sheepshank would be ok for shortening but requires the line/strap to be taut for the knot to hold. I'd shy away from it though, a sheepshank is not a knot i would trust to hold me hanging off a cliff, and not something i would use for recovery. Like someone said, doubling up the strap is the best method to shorten it.
A double bowline, while it would shorten the line, could be very difficult to untie if i both bights weren't pulled equally and the knot collapsed.
The picture someone else showed off how to tie 2 straps together looked good, but i might try "tying" a larks head. You just stick one end of the looped strap through the loop of the other one, and then feed the strap back through its own loop. In my experience, they've always been easy to untie. ANd that would definetly be better than using a shackle in the middle, that could be deadly.
Just some thoughts
1995 4.0 AW4 NP231 C8.25" "Miss Molly"
Rusty's 3", ProComp SS, JKS Adj Track Bar
sailgclass is offline
post #17 of 29 Old 11-05-2006, 10:10 PM
Rescue XJ
The sheepshank is the premier knot for shortning ropes.
He asked for a knot to shorten a rope, I gave him one.
The sheep shank also is good for bypassing a damadged section of rope, and in some cases joining two sections of rope.
I agree, a larks head would be a good choice in this situtation, way to think outside of the box.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #18 of 29 Old 11-05-2006, 10:14 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Just some thoughts
If you tie the sheepshank and leave the loops large, you can pass the standing ends through effectively making a pair of bowlines, but without the loops tightening. Makes it less worrisome on keeping the lines tight. You could also use some electrical tape to keep the loops in place.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #19 of 29 Old 11-06-2006, 06:37 AM
tommaho
tommaho's Avatar
The picture someone else showed off how to tie 2 straps together looked good, but i might try "tying" a larks head. You just stick one end of the looped strap through the loop of the other one, and then feed the strap back through its own loop. In my experience, they've always been easy to untie...
I tried that once, and it made me the proud new owner of a 70' recovery strap. Me, and three or four other guys couldn't budge the knot and I still cant think of a way to soften it without damaging the strap.
tommaho is offline
post #20 of 29 Old 11-06-2006, 08:11 AM
TJ on the Rocks
TJ on the Rocks's Avatar
TJ on the Rocks is offline
post #21 of 29 Old 11-06-2006, 09:18 AM
sailgclass
1986 FSJ Wagoneer
interesting. haha, so maybe you shouldnt try a larks head. sorry to hear that. interesting idea about the sheepshank and the standing end, making sheet bends. could be worth a try, but that could be much harder to untie than a sheepshank, although it would undoubtedly be stronger.
here's a thought, what about tying a butterfly knot in the middle of the line and using it to pull from and thus shorten the line.
post #22 of 29 Old 11-06-2006, 11:02 AM
firejeeper
Originally Posted by Mikey B
I think the saying goes,
Ask a sailor to tie you a knot
but remeber tying knots reduces the breaking strength of a line, and just for argument sake, I used a bowline the other day when I got a truck stuck in sand and it came right out afterwards
Mikey b
A boline will work but like you said. Any time you bend a rope, you loose strength. If you use a figure eight on a bight, you loose some strength but you also have one of the safest knots around. It is used for multiple life saving events. I would suggest that you just use a shorter strap for safety sake.
firejeeper is offline
post #23 of 29 Old 11-06-2006, 04:49 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
the rabbit comes out of the hole ,go's around the tree and back in the hole...I'll never forget that..lol..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #24 of 29 Old 11-06-2006, 05:52 PM
bsruther
bsruther's Avatar
A knot is always the weakest point. I'd never tie any kind of knot in a strap.
Wouldn't it be cheaper and safer to just buy a shorter strap.
http://en.wikipedia.org/wiki/Knot
bsruther is offline
post #25 of 29 Old 11-06-2006, 06:25 PM
I FLEX
I FLEX's Avatar
Originally Posted by Blue XJ
NEVER use a d-ring to join more than 1 tow strap, if the strap broke, the d-ring will come flying right back at you. Many people have died from this.
To tie two straps together, get a small stick and put it in the middle of the knot, this way they can be removed after they are used.
Me and a buddy had to do this with 3 tow straps. We were wheeling on a snow and ice covered switch back and i got stuck. My buddy wasnt able to turn around to winch me nor could a snatch block be deployed. We tied the 3 straps in the method above and he tugged me back onto the path. It was rather easy to undo the knot or wrap...whatever they're called.
- Micah
Muddy TJ
2001 SE 5spd | 33x12.5x15 Toyo MT's|
RE.BB with RE3.5 shocks | Anti-Rock
#13
(they are some what updated)
I FLEX is offline
post #26 of 29 Old 11-06-2006, 06:36 PM
RWB214
RWB214's Avatar
I used a larks head on the receiver shakle the other day to pull a post out of the ground... it was pretty tight afterwards
RWB214 is offline
post #27 of 29 Old 11-15-2006, 03:19 PM
Z0RR0
Since no one mentioned it, I'll go.
You can undo knots by hammering them loose. Just take a random hammer and gently bang on it in all the directions you can think of, and slowly you'll be able to get it free.
Has worked for me on everything, from the little tie-down straps to the big recovery strap (now why that one had a knot, I'll never figure out ... oh yeah, because I tore it apart. Doh.)
Z0RR0 is offline
post #28 of 29 Old 11-15-2006, 03:47 PM
mylt1
mylt1's Avatar
a hammer will damage the threads of the rope/strap. if you have done this to a recovery strap i wouldnt want to trust my life on it. as stated before a not will weaken the strap and could cause damage. just fork out the cash for a shorter one.
mylt1 is offline
post #29 of 29 Old 11-18-2006, 08:13 PM
Faramir66103
I really agree that the best idea is to either double the long strap back, or just carry a couple of straps of different lengths. If you're wheeling with a group, each of you only needs one, as long as they're differing lengths.
One reason knots are going to be hard to untie is that they stretch under load, and then once the stress is removed, that tension will still be in the knot. Not to mention the vast decrease in strength a knot creates.
I'm a former Boy Scout, I've taught wilderness search and rescue and I've rigged speaker arrays all over the world, for what it's worth.
If you're interested in knots in all sorts of materials, check out "Wilderness Search And Rescue" by Tim J. Stenicka. He's worked SAR teams in Yosemite, Glacier Bay and Grand Teton. That book is full of just about everything you could ever want to know about SAR. Another book that's really good is is "Stage Rigging Handbook" by Jay O. Glerum. And of course Bill Burke's stuff is fantastic.
FWIW,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
Recovery Using Tow Straps DaOne General Jeep & Off-Road Equipment 19 08-24-2007 11:06 AM
Recovery Straps? jeepsurfgirls General Jeep & Off-Road Equipment 19 05-07-2007 04:40 PM
Recovery straps, best brand? SierraDave General Jeep & Off-Road Equipment 11 01-11-2007 08:04 AM
Straps for recovery articulate General Jeep & Off-Road Equipment 8 07-11-2005 11:30 AM
Recovery / tow straps NIN_Jeep General Jeep & Off-Road Equipment 6 01-17-2004 03:21 PM
