Tying flat tow straps. - JeepForum.com
post #1 of 9 Old 08-06-2013, 03:10 PM Thread Starter
Holder350
1995 XJ Cherokee
OK so I know its a really bad idea. But things happen on the trail, and sometimes straps break.
Is there any kind of procedure to temporarily repairing them? Or just knot them together and pray nobody else gets stuck?
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #2 of 9 Old 08-06-2013, 04:08 PM
wilson1010
No tow strap should ever break. If you use a 3" or 4" polyester strap you cannot break it with a Jeep. Throw your 2" straps and ropes away and buy two 4" yellow poly straps looped at both ends and two 3/4" D shackles and you will never have to consider this question.
If you must tie a 2" strap, be sure that you have tied a square knot. If you have no shackle, then tie a slip knot with the loose end. Then throw it away when the task is done.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 9 Old 08-06-2013, 04:14 PM Thread Starter
Holder350
1995 XJ Cherokee
The reason Im asking is that I have one that broke......(not from strain but from catching a sharp corner and ripping.)
Just wondered if there actually was a way to continue using one that had been damaged in an emergency situation.
post #4 of 9 Old 08-06-2013, 06:29 PM
biffgnar
biffgnar's Avatar
Square knot? I was under impression there were much better knots for joining two ropes - e.g. fisherman's knot, sheet bend. Although can't really imagine tying any of them in a recovery strap.
Romney in 2020!
biffgnar is offline
post #5 of 9 Old 08-06-2013, 06:55 PM
mike_dippert
mike_dippert's Avatar
Throw it away and buy a new one.
mike_dippert is offline
post #6 of 9 Old 08-06-2013, 07:44 PM
wilson1010
Permanent splicing of a tow strap is not possible. I suggested a square knot because it is harmless enough for an emergency on the trail. And most people can pull it off if they know the difference. There are indeed knots that will not come apart. Buy a copy of Chapman's Piloting ($5 on Half.com) if you want to learn some. The knots are on page 200 or so.
Still, I agree with myself and others - throw it away.
post #7 of 9 Old 08-07-2013, 05:53 PM
olliehopnoodle
1982 FSJ Cherokee
Use your buddy's strap. If everyone carries one it wouldn't be an issue if one tore.
Also, tow straps should not be used for recovery purposes, broken or otherwise.
A tied TOW strap would probably be okay for TOWING in a pinch but only on the trail and depending on the condition of what was being towed.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #8 of 9 Old 08-07-2013, 06:10 PM
mike_dippert
And to clear this up...
Tow straps do not stretch. Recovery/snatch straps have a little elasticity.
post #9 of 9 Old 08-08-2013, 07:05 AM
notmyj
Cut the loops on the torn strap and toss it the garbage. Before you buy another one, have a look at the recovery gear link in my signature so you know what KIND of strap to get. They are not all created equal.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
