Turbocharger, and Fuel Efficiency - JeepForum.com
post #1 of 2 Old 09-15-2010, 03:18 PM Thread Starter
Lars_Eptaimeros
I was wondering what all I would need to do to be able to install a turbocharger in my 1998 Grand Cherokee, it's a v8 5.9L. I'm also curious about way to get better gas mileage. Thank you.
Lars_Eptaimeros is offline
post #2 of 2 Old 09-15-2010, 03:37 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
a turbo definitely won't give you any better mileage. you're increasing the volumetric efficiency of the engine, and to maintain a safe A/R ratio, you'll be feeding it even more fuel. on your V8, it will probably cut 2-3mpg off your mileage, even when driving it easy.
but to install a turbo setup - you'd need some custom exhaust manifold work, either custom headers, or to pipe the exhaust flow to a turbo...probably be easiest to do a remote mount.
then you'd need another set of piping to run the intake air into the inlet of the turbo, and from the turbo outlet to the throttle body. this stuff is generally 2.5" to 3" thin wall metal tubing. it would also be ideal to run an intercooler in front of the radiator, which would more than double the tubing requirements.
then you'd need to do some tuning to the ECU so it would maintain proper A/F ratio across the RPM range...that means some dyno time at a shop, and you'd probably need to buy a piggyback ECU, but i don't know how smart the 5.9L ECU's are.
All that has been done...Dodge 5.9L R/T Magnum's were pretty hot trucks to build up back in that time period. KRC Performance used to be a big player in that area. They had a ZJ running 11's in the 1/4 mile, and they had a twin turbo 5.9L Magnum R/T pushing like 800hp or something ridiculous.
krcperformance.com
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
efficiency , efficient , fuel , turbo
Turbocharger mount jeepinjim Fabrication Shop 17 04-19-2010 10:59 PM
fuel pump runs but not gettin any fuel chall08 Engines & Drivetrain 2 01-26-2009 05:04 PM
Fuel pump to fuel line fittings andynotandy Engines & Drivetrain 1 11-01-2008 08:56 PM
Turbocharger BajaFire Street Jeep Forum 65 02-23-2007 11:04 PM
as I promised...my turbocharger write up... Bryson Street Jeep Forum 58 09-27-2006 08:36 PM
