Tuffy Security Console Lock - JeepForum.com
post #1 of 9 Old 07-24-2010, 12:05 AM Thread Starter
Heywoz
I have a Tuffy Security Center Console for the Wrangler JK. I locked it last night with a bunch of valuable stuff in it, and now it won't unlock. The key won't turn a complete 180degrees and unlock. If I force the key, it will finish spinning the 180degrees, but it won't unlock, it's like the mocking mechanism just spin's without actually unlocking.
I'm 99% sure that there isn't anything behind the lock. The lock locked without a problem last night.
I called tuffy and they suggested drilling out the lock.
I would like to avoid drilling the lock out.
Any suggestions?
Thanks for the help!
Heywoz is offline
post #2 of 9 Old 07-24-2010, 06:28 AM
Viencent
1982 CJ7
Drilling it is the only way I can think of
Viencent is offline
post #3 of 9 Old 07-24-2010, 08:21 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If there was another method besides drilling, that would mean the Tuffy isn't all that secure... but it is. My bet is the lock nut or something close by wasn't tightened properly or something has popped up from inside the console to block it. I had three different Tuffy products in my last TJ and none ever gave me any locking/unlocking problems unless something I had placed inside of one of the boxes had moved into the way.
Jerry Bransford is offline
post #4 of 9 Old 07-26-2010, 08:50 AM
Gunga
1978 CJ7
You do have to drill it.
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #5 of 9 Old 07-26-2010, 09:04 AM
ZeroGravity
I would give the cylinder a couple taps with a small hammer and try again. Maybe some lubricant. Don't beat the thing to death but just enough to move things around hopefully. Maybe it's just gummed up? I mean, if you're going to ruin the cylinder with a drill you might as well exhaust any other options you have.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #6 of 9 Old 07-27-2010, 08:56 AM
Gunga
1978 CJ7
You can try whatever you want but having gone thru this, you have to drill it out. It's not the locknut. If the whole cylinder is turning it's probably the screw that secures the tab that flips over and locks. If that tab's come off it has nothing to stop it from just spinning. Tuffy will send you a new lock for about $25.00 and they will tell you the trick to open it once you've drilled out the lock. It will not just open up after you drill it, which is another benefit of the Tuffy products. With the lock drilled out, it's still not easy to open.
Gunga is offline
post #7 of 9 Old 07-29-2010, 08:14 PM
NonRubicon
Try a locksmith?
NonRubicon is offline
post #8 of 9 Old 07-30-2010, 08:29 AM
Gunga
1978 CJ7
Originally Posted by NonRubicon View Post
Try a locksmith?
That would cost more than getting a new lock.
Gunga is offline
post #9 of 9 Old 07-30-2010, 08:37 AM
KevinR
1983 CJ7
If you think that something may have shifted and blocked the lock, take the Jeep for a ride off-road to jostle things around a bit. Worst case scenario, you still have to drill it out, but you got to go off-roading
KevinR is offline
Tuffy Security Console/Glove Box install JerseyDoug General Jeep & Off-Road Equipment 0 06-06-2010 05:59 AM
Tuffy security box and subs Haik Audio, CB & Ham Radios, GPS, & Electrical 8 04-14-2008 11:39 AM
Amp in a Tuffy security drawer? j881972 Audio, CB & Ham Radios, GPS, & Electrical 3 04-26-2005 03:20 PM
Tuffy Security consoles: Stereo Problems? ArmySGT Audio, CB & Ham Radios, GPS, & Electrical 5 03-27-2005 08:24 PM
basslink and tuffy security trunk judge_schmells Audio, CB & Ham Radios, GPS, & Electrical 2 01-06-2005 08:53 AM
