Truck-Lite vs J.W Speaker LED Headlights - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Truck-Lite vs J.W Speaker LED Headlights
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-18-2015, 02:11 AM   #1
kam1
If somebody is thinking to upgrade their headlights, I made a little video comparing 2 big brands
JW Speaker vs Truck Lite LED vs stock headlights on Jeep Wrangler JK
kam1 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 08:43 PM   #2
jcaloncagon
Thanks for sharing!
jcaloncagon is offline   Reply With Quote Quick reply to this message
Unread 06-07-2015, 12:40 PM   #3
Ef4life
So which do you like better in person?
The pictures I like the truck lights best, the jw seems almost too bright up close.
Ef4life is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 06:00 AM   #4
97Heep
97Heep's Avatar
To me the JW look too bright up close and little to no difference between lo and high beams along the side of the road.
The stock JK lights look worse than my stock TJ lights... that's interesting if actually true, and quite sad.
Truck Lites have gone through 2 versions of their lights that I am aware of. The first set got very poor reviews from Jeeps owners; so, I assume this is the 2nd version?
'97 Jeep Wrangler Sport TJ 4.25" lift 33x10.5x15 KM2's (Sold)
'04 Jeep Wrangler Rubicon TJ - She's Savvy
97Heep is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 11:27 AM   #5
Demp
I'm running the JW Speaker 8700 Evolution, which is what he seems to use in the video. The video shows a pretty fair comparison of all three.
The JW Speaker does have a far cast, leaving less light directly in front and to the sides. The 6145 Fog Lights make up this difference.
The High Beam is a brighter, higher pointing driving beam, you don't gain much more to the sides as those separate emitters dont change.
You can see the Trucklites have a lot of artifacts in the light pattern, which bother some people. Still far outperforms the stock.
Demp is offline   Reply With Quote Quick reply to this message
