tree saver - JeepForum.com
post #1 of 15 Old 11-16-2005, 11:25 AM Thread Starter
Hepyrunner
Junior Member
tree saver
with an 8,000lb winch how stong of a tree saver should i get? I found one that is rated at 8,000lbs but does it need to be double or anything like that?
Hepyrunner is offline
post #2 of 15 Old 11-16-2005, 11:45 AM
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
In theroy you should be ok, but I always like to have a little safety margin I would get one a little stronger, as with everything overtime the strength will weaken and that might be when you need it most
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline
post #3 of 15 Old 11-16-2005, 02:48 PM
got_4_lo
i would not trust a 8000lb tree saver... go w/ a 15000 or 20000 to be safe...
-Shayan A.K.A: Sean
Originally Posted by DesertTJ
I came home to be spit on and protested against in Boulder, Colorado. Most of the people have no clue. And that's why we do what we do. We give up our freedom so they can enjoy their freedom.
got_4_lo is offline
post #4 of 15 Old 11-16-2005, 05:33 PM
lupinsea
lupinsea's Avatar
I run a 3" 30,000 lb. 10ft long tree saver. I would think you'd want to make sure you have a very sturdy anchor point. I was debating the 6 ft vs. 10 ft length and decided on the 10 footer because we have some big-*** trees up here in the NW. And some times the 10 ft length still isn't long enough, but thats only for the biggest of the big trees. The rest of the time it works great.
FYI, the 10 ft tree saver ran about the same price as my 2" x 30 ft 20,000 recovery strap. I can't remember the maker but the ones I bought came with an elastic loop sewn in so that after everything is wrapped up for storage you just slip the elastic loop around everything to keep it from unravelling.
- Jay
lupinsea is offline
post #5 of 15 Old 11-16-2005, 08:35 PM
U.S.MarineLJ
U.S.MarineLJ's Avatar
This is some good info, thanks guys, and thanks for asking the question as I never thought about this and I will be picking up the related recovery gear for my winch shortly.
John.
Now what is your input on a snatch block? And do I need a choker chain?
Great site to read about and review Jeep related products.
Awesome site with writeups.
Another awesome site for writeups.
U.S.MarineLJ is offline
post #6 of 15 Old 11-16-2005, 09:17 PM
dynamite44
last time i was with a group that used a chain, this happened:
after that, i've done my best to stay away from the use of chains. the warn choker chain is very similar to one sold at home depot. the one at home depot comes in a little white plastic bucket, and costs like half of what the warn chain costs. looks the same.
id say if you're going to use a chain, get the biggest @ss chain you can find, just for a little extra reassurance.
2000 XJ silverstone metallic.
dynamite44 is offline
post #7 of 15 Old 11-17-2005, 02:06 AM
lupinsea
lupinsea's Avatar
My understanding of choker chains is to attach your Jeep to an immovable object (such as a tree) so that you won't be pulled forward if you're trying to help winch someone else out. They shouldn't be used as a "recovery strap" to yank someone else out. Also, there is different quality and stregth of chain that you can get in the same size. I have no idea what type of chain Warn sells but I wouldn't be surprised if it's a higher grade than the local Home Depot variety.
The snatch blocks are awesome. I've used mine about 70 - 75% of the time I've used my winch. Mostly it was to re-direct the winch line to a better vector. Here are examples of how I used my Warn snatch block:
Scenario 1
I was the lead rig on one outting that turned into a snow run. The guy two Jeeps behind me was having problems getting up a hill and didn't have a winch on his rig. No problem: I hooked the tree saver around a tree off to my right, connected the loops with a d-shackle that also secure the snatch block and ran the winch cable 170 deg behind me to pull the guy up the hill.
Scenario 2
Another time I was following a guy in front of me without a winch. He was having difficult making it up a particular obstacle. No problem.... run the winch line to a tree 20 ft in front of him where we anchored a snatch block to a tree with the tree strap and redirected the line back to the front of the guy's Jeep. Pulled him right up.
Scenario 3
When I was stupid and out wheel'n alone I was driving over some washed boulders and shattered my t-case in the middle of the trail. Couldn't back up because some bolders were piled up directly behind me. No problem (sort of): I hooked up the tree strap and snatch block directly behind me, ran the winch cable under the Jeep, out between the rear tires, through the snatch block and directed the line straight back to the rear of my Jeep (360 deg?). There I wrapped my 30 ft tow-strap around the boulders and dragged them backwards with the winch cable. Then I repositioned the snatch block and tree strap 90 deg to my left and dragged the boulders sideways out of my way. Then ran the winch cable back under my Jeep to a tree 100 ft down the trail directly behind me and hooked it to the tree strap. Pulled the Jeep down out of the rocks to a side spot where I could park it and go for help. (I no longer go wheel'n alone)
I assembled my own "accessory kit" and keep it in the Jeep with me. Everything is kept in a $10 tote bag from Target that I can just grab and go if I need my accessory equipment. The "kit" consists of:
  • 30 ft x 2" 20,000 lb. recovery strap with loop ends (no hooks)
  • 10ft x 3" 30,000 lb. tree strap
  • Warn's snatch block (others work well, too)
  • 2 D-shackles
  • $5 pair of sturdy leather work gloves (for handling the cable and stuff)
  • $10 tote bag w/ handles I keep everything in from Target
- Jay
lupinsea is offline
post #8 of 15 Old 11-17-2005, 02:43 AM
got_4_lo
Scenario 1
Scenario 2
Scenario 3
  • 2 D-shackles
that's some impressive use of taht snatch block... i can tell you played w/ erector sets and legos when you were a kid
-Shayan A.K.A: Sean
got_4_lo is offline
post #9 of 15 Old 11-17-2005, 02:46 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Haven't pulled out any cement trucks have you?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #10 of 15 Old 11-17-2005, 05:57 AM
CNY
Don't you need two snatch blocks for that?! Hahahahahahahahaha
CNY is offline
post #11 of 15 Old 11-17-2005, 06:14 AM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I'd suggest to buy the strongest one you can get your hands on... and buy a couple of lengths if only so you have an extra in case one gets trashed on the trails.
Overkill... just keeps you from killing someone.
I'll be Savvy someday!
neZZr is offline
post #12 of 15 Old 11-17-2005, 08:18 AM
dynamite44
i havn't found the specs on warn's choker chain anywhere. you think they'd post the specs if it were amazingly great, like how many lbs capacity. at least depot's chain does.
i agree with nezzr, and overkill never hurt anyone.
snatch blocks are fun, just make sure you've got some good Drings that are capable of taking the weight. if there are any boat supply type places around you (west marine, boatUS, boatersworld...) check out their anchor dept. they have cheap Drings.
post #13 of 15 Old 11-17-2005, 11:13 AM
HKP7M8
HKP7M8's Avatar
Acualy on warns site it mentions that its grade 7 chain. as there is no grade 7 chain its probibly grade 70 chain. which in the 5/16th size warn spec's its WLL is 4700 lbs. That means a minimum brake strength of 23500lbs. thats more then twice the WLL of the 5/16th wire rope that comes on the 9500lbs and below winches.
2003 Inca Gold Rubicon. Mostly Stock.
The P7 is the Hannibal Lecter of autoloading pistols
Caution: Pistol may torture, kill and eat other pistols.
HKP7M8 is offline
post #14 of 15 Old 11-17-2005, 11:31 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
MI have no idea what type of chain Warn sells but I wouldn't be surprised if it's a higher grade than the local Home Depot variety.
The chain I see at my local Home Depot is all unrated. It's just like common hardware vs. Grade 5 and Grade 8 rated hardware. Chain used for vehicle recovery and highway use like for transport hold-down must be rated.
Jerry Bransford is online now
post #15 of 15 Old 11-17-2005, 12:02 PM
ncb76
ncb76's Avatar
Home Depot and Lowe's do sell rated chain (gade 70). At least around here. But not every chain they carry is rated that high. Always double check and if in doubt don't use it.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
Is a 6' tree saver strap long enough for CO? mizedog General Jeep & Off-Road Equipment 5 01-27-2010 10:33 AM
can a recovery strap be used as a tree saver? alecmcmahon General Jeep & Off-Road Equipment 34 06-24-2009 06:35 AM
recovery vs tree saver straps kllrbee General Jeep & Off-Road Equipment 5 12-05-2008 11:27 PM
Great Deal on a 4" x 30' Tow Strap / Tree Saver CopperCJ7 General Jeep & Off-Road Equipment 6 09-03-2008 05:26 PM
Snatch block and tree saver? jeepfury General Jeep & Off-Road Equipment 3 11-10-2005 09:40 AM
