transfer cases? - JeepForum.com
post #1 of 4 Old 08-18-2001, 11:24 PM Thread Starter
rondog
transfer cases?
I'm getting ready to purchased a "pre-owned" (LOL) Cherokee and it looks like I'll be looking at a some with the command trac and the select trac 'cases...I need some opinions... Command Trac or Select Trac?
Thanks
'80 CJ-7... Rubicon? You Bet !
rondog is offline
post #2 of 4 Old 08-21-2001, 11:48 PM Thread Starter
rondog
I bought a '93 XJ with the NP231... so I guess it doesnt matter any more...lol
rondog is offline
post #3 of 4 Old 08-25-2001, 04:21 PM
Nightclaw
You're probably OK with the NP231. As long as the chain is in good shape (no chain slapping in 4WD), you should have no problem. Do change the oil though, as God only knows if the previous owner(s) did or didn't do so. So, when are you going to install a Tera 4:1 conversion...?
'94 YJ Sahara Hardtop
4.0L / AX-15 / Stock NP231 / Stock D30 (open) / D60 (35-spline, Detroit locker, Moser axles) / rear disc brakes / 4.56 gears / Advanced Adapters SYE & CV Shaft / 33" BFG MT-KM's / Thorley Header / Magnaflow Muffler / BesTop Flares
Nightclaw is offline
post #4 of 4 Old 09-04-2001, 11:25 AM
Matt B
Seems that selec-trac is popular for people in snowy-icy areas which don't feel like shifting in and out of 4wd high all the time when road conditions don't need it.
Matt B is offline
1998XJ and TJ T-cases? Jeepguy1977 Engines & Drivetrain 1 06-09-2009 05:56 PM
Transfer case will not go into 2WD WhiteChoc0late Engines & Drivetrain 1 08-27-2008 07:22 AM
Anyone in Dallas weld aluminum cases ie.. TC cases? RedRubiconLJ General Jeep & Off-Road Equipment 4 08-16-2004 07:42 AM
Np 208 transfer cases 79cherokee Engines & Drivetrain 1 05-26-2003 01:24 PM
Transfer Cases..... evilpsych Engines & Drivetrain 3 02-14-2002 08:30 PM
