Transfer Case vs Axle Lockers - JeepForum.com
post #1 of 17 Old 01-25-2014, 03:14 PM Thread Starter
Schwarzy
I'm on another forum, and this is driving me nutz the general conclusion there is that going from 2.7 to 1 transfer case to 4 to 1 transfer case is better than installing a locker in the rear axle. I feel like I'm going crazy arguing for the locker.
1998 ZJ Jeep Grand Cherokee Limited I6
Lifted LA 7", Goodyear MTR's 33", Winch, Bumpers, Sliderz, 4.10, Locked, and Loaded.
Schwarzy is offline
post #2 of 17 Old 01-25-2014, 03:18 PM
krawler510
If it was the same price I'd rather have the 4.1 in my XJ.......... Sorry.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #3 of 17 Old 01-25-2014, 03:20 PM Thread Starter
Schwarzy
I need to rephrase it, which will get you further down the trail.
Schwarzy is offline
post #4 of 17 Old 01-25-2014, 03:25 PM
streetglideok
2005 KJ Liberty
Lockers IMO. 4:1 tcase will do a lot, but two wheels biting with an ultra low tcase isn't going to go as far as 3 wheels or 4 wheels biting with 2.7:1
streetglideok is offline
post #5 of 17 Old 01-25-2014, 03:27 PM Thread Starter
Schwarzy
My thinking exactly.
Schwarzy is offline
post #6 of 17 Old 01-25-2014, 05:53 PM
biffgnar
biffgnar's Avatar
Lockers by a mile!
Romney in 2020!
biffgnar is offline
post #7 of 17 Old 01-26-2014, 10:04 AM
BlueRubiconrich
lockers!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #8 of 17 Old 01-26-2014, 10:25 AM
1222
RIP John
1222's Avatar
Just common sense; locker.
(2011-2016)
1222 is offline
post #9 of 17 Old 01-26-2014, 11:13 AM
strvger01
1966 CJ5
locker. no doubt about it.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #10 of 17 Old 01-27-2014, 08:11 AM
Ross
lockers, without traction you will spin regardless of your gearing. With traction you can move forward. I suppose in high traction steep angles the gearing may have its advantage.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #11 of 17 Old 01-27-2014, 08:45 AM
zillla
1930 VJ
Lockers.. I don't carre how low you gear. Without traction you are not going anyplace..
Pull my finger
zillla is offline
post #12 of 17 Old 01-28-2014, 07:59 PM
danj
+1 for lockers
2001 TJ-35'' BFG- 4.5 ''Long Arm Rubicon Lift -Dana 44 -488's- Currie anti-rock-
danj is offline
post #13 of 17 Old 01-28-2014, 09:05 PM
Indy
Indy's Avatar
Winch, gears, locker in that order as to which to get first. A winch will help get you not dead in the middle of nowhere. Gears will help you get to the middle of nowhere easier and a locker will help the middle of nowhere move into the real middle of nowhere. If you lock first and get waaaay out there and stuck, you're really in a bad spot.
Gears alone wont get you an inch further regardless of the ratio. Once youre spinning two, you will be just as stuck with a bazillion to 1 ratio as you would be with a 2 to 1.
I'm the only gay eskimo.
Indy is offline
post #14 of 17 Old 01-30-2014, 04:31 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
x2 on locker, especially for the rear first. Oddly, after I installed the klune V under drive giving netting about 200:1, with sufficient articulation, ARBs are not used as much as before. Lower gears really slow down the action and offers more reaction time in the rocks. I do not care for the 4:1 swaps since you then have all or nothing. Oftentimes, that silly factory low range gear set is nice for cruising back roads, etc. The separate under drive allows retention of unmolested D300 and several more trail gearing options depending on the terrain.
which will get you further? rear locker, but then it might get you too far, LOL. Good luck
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #15 of 17 Old 01-30-2014, 08:16 PM
olliehopnoodle
1982 FSJ Cherokee
I would tend to agree with the locker first but I have not seen the other side of the argument articulated. Generally a build progresses with gears/lockers/TC.
I started ARB in the back, moved to lunch box in the front, and finally Atlas (2.0/2.72/5.44). Soon I will be converting to ARB front/rear and when I do I will try out wheeling in 5.44 and not locking the axles to see what happens.
Here on a Arizona trails a two speed transfer case that is 4.0 would drive you nuts. The slow speed of 4.0 would be a pain on the mild 'trail hills'.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
